01-12-2009, 07:03 PM #1
Teardown manual for McQuay/Westinghouse PE Centrif
Many many many moons ago I used to do complete maintenance (including teardowns) on Westinghouse PE centifs but mislaid my manuals years ago through lack of use...(silly boy)...I now want teardown info on Mcquay PE centifs..( single compressor) circa 2000/2006 anyone out there able to help??...I may well be able to reciprocate with info as have extensive library...
Not getting wiser at the same rate as I am getting older??
02-12-2009, 08:46 AM #2
02-12-2009, 06:29 PM #3
Re: Teardown manual for McQuay/Westinghouse PE Centrif
Have sent you message..thanks!
SEEMS YOU ARE NOT ACCEPTING PRIVATE MESSAGES...TRY YOUR VISITOR MESSAGES!!Last edited by Superheatman; 02-12-2009 at 06:43 PM.
02-04-2010, 12:48 PM #4
hi superheatman
worked for mcquay some time ago
post email and can send an 087 manual
aww
Airwell BS 36 Technical Manual
By Electricliff in forum Air ConditioningReplies: 14Last Post: 17-12-2009, 12:04 PM -
19 XR Teardown Manual
By Shakey in forum Air ConditioningReplies: 8Last Post: 08-05-2009, 05:25 PM -
Creating Troubleshoot manaul (Fault Code Manual)
By Roan in forum Trouble ShootingReplies: 2Last Post: 25-02-2009, 08:11 PM -
Westinghouse freezer - can it be made manual defrost?
By billv in forum DomesticReplies: 6Last Post: 04-01-2009, 07:30 PM -
HP Switches (Manual or Auto)
By Latte in forum Technical DiscussionsReplies: 9Last Post: 02-06-2005, 07:48 PM
