Thread: pentane
    Feb 2005
    sliema
    52
    138
    Exclamation pentane
    Hi All,
    I came across a two door refrigerator,almost new that runs on pentane.Well call was as it was not cooling enough.I read a freezer temperature of -11 degrees celcius and 14 degrees celcius in refrigerator,well far from the normal temperatures expected from my side.I was in the verge to install a pierce vale to check suction pressure but was faced with the problem to braze back the pipe.I have a crimping tool but obviously has to braze the pierced copper.What can be done with these newly designed refrigerators as pentane is highly flamable and do not think is a good idea getting close with a brazing torch ! Any help would be appreciated.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: pentane
    Need to recall it and recharge.
    Feb 2005
    sliema
    52
    138
    Re: pentane
    Yes but how about to close pierce of valve or shall I leave one installed there ?
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: pentane
    It won't harm to leave it there as soon as it's leak tight.
    Feb 2005
    sliema
    52
    138
    Re: pentane
    Ok then will do it this way.But if there's a circumstance that one has to open system,how can he braze if the gas is flamable ?
    Mar 2009
    KZN, South Africa
    64
    2,212
    Re: pentane
    ^ I'm not sure what the other members may suggest, but I'd recover refrigerant, vacuum, purge with OFN (repeat at least 2x), measure pentane levels % - check not near explosion point - set strong OFN purge, get brazing.
    This kind of thing is done in refineries & chemical plants routinely. There will always be some level of risk, with refrigerant hiding in system. A good OFN blanket is useful.
    Not sure if there are other better blanketing gases around. I'd be interested to hear comments.
    With this kind of job, I'd take along a spare pair of underpants - you may need them.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: pentane
    Quote Originally Posted by kerrcell View Post
    you can't, as DesA explained.
    Sep 2008
    Letsby Avenue
    359
    Re: pentane
    Supco answered an email in which I asked if their peircing valve is considered suitable for use on hydrocarbons and they answered yes.
    They are a permanent fix when fastened down after testing.
    Feb 2005
    sliema
    52
    138
    Re: pentane
    Ok thanks so better keep a fire blanket just in case.
  1. Charging Pentane
    By lsmith3023 in forum Refrigerants
    Last Post: 23-11-2010, 11:25 AM
  2. Is POE bad for R407C ?
    By Acrisoft in forum Refrigerants
    Last Post: 24-09-2009, 05:24 PM
  3. Pentane or Propane?
    By Bones74 in forum Refrigerants
    Last Post: 13-02-2008, 08:56 PM
