    Dec 2008
    UAE
    Grasso imbalance
    Guys,
    I was told by one of the guys here that Grasso Screw Compressors have some sort of an imbalance and that they cause a damage in the long run. The guy suggested to use Sabroe as well. Is there any truth in the same? As far as I know both the brands are equally good. Please provide inputs on the issue.
    Thanks very much.
    Nov 2005
    New Zealand
    550
    Re: Grasso imbalance
    Quote Originally Posted by SirajN View Post
    Guys,
    Thanks very much.
    Hi SirajN, You have posted this three times, all you require is one post.
    Norm
    My wife used to say you never listen to a word I say at least I think that what she said
    3,357
    There is a inbalance in Grasso if you have to higher oil pressure in some models .
    What type of Sabroe machine is being offered ?
    Dec 2008
    UAE
    Quote Originally Posted by Toosh View Post
    Norm
    Hi Guys,
    I am sorry for posting it three times. I am not a regular user hence kindly excuse my ignorance.
    Dec 2008
    UAE
    Hi Ranger 1,
    Its actually not just one particular model of Sabroe. I was tod by York that Sabroe has since long stopped production in Denmark, so the compressor block is the same from Frick. However they still sell the Sabroe brand and use leroy Somer motors and it has CE certification for the complete pack.
    If there is an imbalance in some of the models, has Grasso rectified the same? or does it still prevail? Could you give an input on exactly whats the phenomenon that happens when there is an imbalance and higher oi pressure? Is it becuase the discharge line is horizontal from the compressor rather than directly down into the oil separator?
    Thanks very much
    Siraj
    3,357
    If oil pressure is to high the extra force on balance piston can drive rotor into discharge end housing .
    This on compressors with full time oil pump .
    They have a lot of stuff to avoid it but it can happen , mainly through ignorance
    Grasso appear easy to work on but Frick type machines are heavy alkward machines to work on .
  1. Grasso imbalance
    By SirajN in forum Industrial Compressors
    Last Post: 16-12-2009, 03:47 AM
  2. Grasso SP2 duo packs
    By aawood1 in forum NH3
    Last Post: 12-06-2009, 10:56 AM
  3. Grasso spares
    By Slush Puppy in forum Industrial Compressors
    Last Post: 23-01-2009, 05:44 PM
  4. KAB S3-900 (Grasso)
    By Gerben in forum Industrial Compressors
    Last Post: 03-12-2008, 07:24 AM
