    Dec 2008
    UAE
    Grasso imbalance
    Guys,
    I was told by one of the guys here that Grasso Screw Compressors have some sort of an imbalance and that they cause a damage in the long run. The guy suggested to use Sabroe as well. Is there any truth in the same? As far as I know both the brands are equally good. Please provide inputs on the issue.
    Thanks very much.
    Dec 2009
    Glenville pa
    37
    4
    Re: Grasso imbalance
    If you're going to swith a grasso or sabroe unit, you are better off to look to mycom or Frick. Parts are more available and less expensive.
    Ben
    tuga2000's Avatar
    tuga2000 Guest
    Mycom and Frick are well know for having the most expensive spare parts. Gosh if you look for a good compressor use J&E Hall or Howden
    Jul 2009
    arkansas
    42
    Hate to tell you this but Frick aquired Sabroe/Stall a few years ago. Its really your opinuion what you chose, just choose whats best for you or your end user
  1. Slide valve wear on Grasso screw after just 54000 Hrs
    By Lodiev in forum Technical Speculations
    Last Post: 14-09-2009, 01:21 PM
  2. Grasso SP2 duo packs
    By aawood1 in forum NH3
    Last Post: 12-06-2009, 10:56 AM
  3. Replies: 2
    Last Post: 25-01-2009, 12:17 PM
  4. Grasso spares
    By Slush Puppy in forum Industrial Compressors
    Last Post: 23-01-2009, 05:44 PM
  5. KAB (Grasso) drawing
    By Gerben in forum Industrial Compressors
    Last Post: 19-01-2008, 01:27 PM
