Thread: Grasso imbalance
30-11-2009, 05:43 PM #1
Grasso imbalance
Guys,
I was told by one of the guys here that Grasso Screw Compressors have some sort of an imbalance and that they cause a damage in the long run. The guy suggested to use Sabroe as well. Is there any truth in the same? As far as I know both the brands are equally good. Please provide inputs on the issue.
Thanks very much.
05-12-2009, 01:10 AM #2
Re: Grasso imbalance
If you're going to swith a grasso or sabroe unit, you are better off to look to mycom or Frick. Parts are more available and less expensive.
Ben
08-12-2009, 10:27 AM #3
Mycom and Frick are well know for having the most expensive spare parts. Gosh if you look for a good compressor use J&E Hall or Howden
16-12-2009, 03:47 AM #4
Hate to tell you this but Frick aquired Sabroe/Stall a few years ago. Its really your opinuion what you chose, just choose whats best for you or your end user
Slide valve wear on Grasso screw after just 54000 Hrs
By Lodiev in forum Technical SpeculationsReplies: 11Last Post: 14-09-2009, 01:21 PM -
Grasso SP2 duo packs
By aawood1 in forum NH3Replies: 7Last Post: 12-06-2009, 10:56 AM -
Grasso SP2 two-stage ammonia screw compressor package.
By Jacek in forum NH3Replies: 2Last Post: 25-01-2009, 12:17 PM -
Grasso spares
By Slush Puppy in forum Industrial CompressorsReplies: 4Last Post: 23-01-2009, 05:44 PM -
KAB (Grasso) drawing
By Gerben in forum Industrial CompressorsReplies: 5Last Post: 19-01-2008, 01:27 PM
