Thread: Expansion valve Changing ?
30-11-2009, 02:31 PM #1
Dear all of you
I have few maneurop compressor that are currently using R22 refrigerant and room temperature +16°C ( Production room ).I need some advise about retrofit R22 to R407C .I m not sure whether want to change expansion valve or not .
Any advise would be much appreciated . Thank you .
oilzee
30-11-2009, 03:13 PM #2
Re: Expansion valve Changing ?
You will have to change the oil in the compressors to POE, clean the system from mineral oil, TXV is almost the same and you can change it or leave it, change the driers and back to work.
30-11-2009, 03:26 PM #3
30-11-2009, 03:48 PM #4
R-507 is for low temp.
If you keep the room temp at 16°C, why not use R-134?
30-11-2009, 04:20 PM #5
Actual Expansion Valve Process
By AastroGuru in forum FundamentalsReplies: 11Last Post: 03-02-2009, 09:53 AM -
Setting of Hand expansion valve
By Iceehot in forum NH3Replies: 7Last Post: 10-09-2008, 01:25 AM -
the function of the electronic expansion valve
By Crystal-426 in forum FundamentalsReplies: 10Last Post: 22-06-2008, 12:29 PM -
Need Divine Intervention - plugged drier or expansion valve?
By archibaldtuttle in forum Trouble ShootingReplies: 4Last Post: 08-06-2008, 06:52 PM -
expansion valve aint cold
By justinworne in forum Trouble ShootingReplies: 6Last Post: 26-07-2006, 10:52 PM
