30-11-2009, 09:11 AM #1
on/off switch contact for Fujitsu ducted AC
Hello, im installing a Fujitsu ducted A/C and would like to interface it with a webserver that remotely monitors temperatures and you can output digital outputs to turn on for example.I would like to control a fujitsu model number AOT36UNAXT. But looking at the drawings i cannot tell how this is done. Other than hacking the wall controller to bits to somhow make it press the power button on/off.
Can anyone could suggest another way please?
Thanks Paul.
30-11-2009, 07:01 PM #2
Re: on/off switch contact for Fujitsu ducted AC
what about putting a contactor on the live off interconecting and powering it with a switch, timeclock etc
02-12-2009, 10:16 PM #3
You must find contact indicating CLK \ USD \ BMS, it should be contact with terminal 2, when a short terminal turns off the air conditioner turns on the short opening the air conditioner (or reverse).The second way is through the communication protocol is hard to believe you can get.
02-12-2009, 10:23 PM #4
If I remember correctly this terminal as JST " CN114 " In the Internal unit
Trane chiller HP Switch
By Kirky in forum Air ConditioningReplies: 4Last Post: 27-10-2009, 09:02 PM -
Dual HP/LP switch wiring - how do you like it wired?
By FreezerGeezer in forum FundamentalsReplies: 15Last Post: 13-10-2009, 02:31 PM -
LoCK out Relay functioning
By ramki in forum FundamentalsReplies: 16Last Post: 02-10-2009, 02:41 AM -
Low Pressure Cut-off switch on Liquid line
By Vishnukurup in forum Air ConditioningReplies: 14Last Post: 03-12-2008, 09:34 AM -
Hermetic analyzer " ANNIE" how do they work
By kengineering in forum Tools and CalculatorsReplies: 11Last Post: 02-03-2008, 06:10 PM
