Results 1 to 2 of 2
Thread: Honeywell Vision Pro 8000
28-11-2009, 09:57 PM #1
I have a Honeywell Vision Pro 8000 thermostat. The red light at the top has a flash code of 2 flashes. Does anyone know where I can find the coding becasuse I cant seem to find it in the manual or anywhere on the internet?
29-11-2009, 06:07 PM #2
Re: Honeywell Vision Pro 8000
The issue was the heat pump would not work and the blower would be working constantly. I found out that sometimes the thermostat malfunctions when put into auto mode. So going into the installers menu and changing that setting will correct this and the heat pump works fine now.
CAREL equavalent of T775M2006 (Honeywell)
By Kaka in forum Technical DiscussionsReplies: 5Last Post: 25-10-2009, 02:34 PM -
Honeywell Residential Controls
By bethlehemtech in forum Tools and CalculatorsReplies: 2Last Post: 12-07-2008, 12:24 AM -
Honeywell chilled water temperature controller
By Cofreth in forum Technical DiscussionsReplies: 4Last Post: 07-09-2007, 06:32 PM -
Honeywell coolmaster recharge
By autochill in forum Trouble ShootingReplies: 17Last Post: 21-08-2006, 11:09 PM -
Honeywell Blue Book
By HVACGod in forum Technical DiscussionsReplies: 0Last Post: 13-05-2006, 03:07 AM
