Results 1 to 13 of 13
    Aug 2009
    uae
    72
    5
    calorex heat pump
    We are have a calorex heat pump AWZ7034BHC with 2 copeland ZR12ME-TWD-551 Compressors Both compressors are burned and need replacement. The compressors are not available anymore here in the UAE. Can I replace these compressors with one double the size hermetic compressor.please advise
    Mar 2009
    KZN, South Africa
    64
    2,212
    Re: calorex heat pump
    Assuming that this is a single lift circuit (not cascade), replacing 2 parallel compressors, with a single compressor, specified to identical operating conditions should be possible - if everything else is able to support it.
    You will definitely need to *carefully* check the equivalent ratings between both compressor units.
    Perhaps you could chat to your Copeland supplier & ask for their recommendations on how to proceed.
    Nov 2007
    Scotland
    67
    141
    I assume you are the ' End User' and you should consult with your local A/C Company on replacing with either Maneurop, Carlyle-Danfoss or Toshiba Hermetic Scroll compressors , there are other equivelant types of course. The system is 2 stage for a reason and I would not consider changing to a single stage if just for economic reasons on running costs alone.You would have a lot of work to do with pipe alterations , electrics etc so just get straight equivelants. Make sure you find out the cause of failure first though!!!
    moideen's Avatar
    moideen is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2008
    u.a.e
    48
    412
    22
    Quote Originally Posted by frederick437 View Post
    this compressor is scroll.available sutable compressor in dubai.go to BNT refrigeration or abu zayed refrigeration.if there not ZR M series,they will arrange zr k SERIES.
    MOIDEEN-DUBAI
    Mar 2009
    KZN, South Africa
    64
    2,212
    Quote Originally Posted by yinmorrison View Post
    I suspect they're a 2 parallel compressor set, to match the heat-load - not 2-stage in series, or cascade.
    Apr 2001
    79
    5,071
    35
    Anyone who needs to ask should not be trying to re-design a 2 compressor system into a 1 compressor system.
    Aug 2009
    uae
    72
    5
    Moideen,
    The problem is that the k series do not have a place for an oil equalizing line
    Aug 2009
    uae
    72
    5
    Gary,
    What would you do then. I need suitable compressors which have the options to install an oil equalizing line
    Aug 2009
    uae
    72
    5
    DesA,
    Yes it is a parallel system no staging. The problem is I need compressors which have the option to install an oil equalizing line between the two compressors
    Aug 2009
    uae
    72
    5
    Yinmorrison,
    No it is two compressors running parallel no staging.The problem is that I can not get hold of same capacity compressors with the option to fit an oil equalizing line between the two compressors
    Apr 2001
    79
    5,071
    35
    Gary,
    You ask if two compressors can be replaced with one. The answer is maybe... but that's the wrong question. The right question is, why does this system have two compressors?
    I don't know the answer, because I can't see the system from here. I can only "see" your description of it... and you haven't described it.
    Mar 2009
    KZN, South Africa
    64
    2,212
    The reason is often that the scroll compressors at the time the heat-pump was developed, may not have had adequate capacity to each cope with the full load. Bitzer, Copeland & others supply parallel sets of matched-performance compressors. These then effectively 'work as one', when linked in parallel.
    Apr 2001
    79
    5,071
    35
    Quote Originally Posted by desA View Post
    That may very well be the reason (albeit not a good reason), but I would not make that assumption.
  1. Addition of a heat pump to solar heating system
    By rt29781 in forum Heat Pumps
    Last Post: 23-01-2010, 08:46 AM
  2. Calorex 510 Pool Heat pump - used
    By vette in forum Heat Pumps
    Last Post: 11-08-2009, 03:14 PM
  3. Calorex 510 Heat pump question
    By jugglerb in forum Heat Pumps
    Last Post: 21-06-2009, 10:49 AM
  4. Pool heat pump water side diagram
    By nike123 in forum Heat Pumps
    Last Post: 22-03-2009, 07:42 PM
  5. frostles heat pump
