25-11-2009, 08:28 PM #1
york chiller ylcs control logic problems
hello, i am looking for information regarding the controls logic used for the york ylcs07255A50yA.
i have a water cooled chiller that does not have provisions for condensor water, there is no space to connect a condensor water flow switch and there is no monitoring of cond. water temp. if the cond pump is switched off, the chiller runs and trips on a manual reset hp switch.
this microprocessor does show provisions for condensor fans.
the chilled water temp. sensor has also been replaced 3 x times from new, the chiller is 2 years old.
information from our local johnson controls guys are not easy available and not very helpful
27-11-2009, 05:30 PM #2
Re: york chiller ylcs control logic problems
Could you confirm model no. pls YLCS0725 ?A 50 YA, ?=S standard unit, H high efficiency, A Remote air cooled. Its not impossible you have the wrong EPROM software fitted. Whichever model you have there is no provision for condense flow switch inputs into the controller, I have previoulsy simply wired in series with the chilled flow switch.
04-12-2009, 12:59 PM #3
Clima Roca York Chiller
By Chinua in forum Air ConditioningReplies: 5Last Post: 13-04-2011, 07:03 PM -
Carrier 30XA Liquid chiller Problems
By Ed Burris in forum CommercialReplies: 7Last Post: 13-08-2010, 08:12 PM -
chiller problems
By iceman6869 in forum Technical DiscussionsReplies: 8Last Post: 19-11-2009, 08:47 AM -
problems with york yaa c chiller
By paulwild in forum CommercialReplies: 4Last Post: 21-08-2007, 08:20 PM -
Water Chiller Control
By David PS in forum Air ConditioningReplies: 4Last Post: 29-08-2006, 11:14 PM
