Thread: parallel evaporator again
22-11-2009, 03:43 AM #1
Thank you Magoo
But sorry I did not right down my problem correctly
I have 3 hp condensing unit connecting to 20000 Btu evaporator of Walk in cooler
Customer wants to add separate Cooler Case (4-6 kbtu) to the same line.
They will work together fine but what
if separately and only Cooler Case (4000 btu)?
Thank you again
22-11-2009, 10:46 PM #2
Re: parallel evaporator again
You might get better response if you post your questions in the correct section.
EC and Air cooled condensers working in parallel
By Josip in forum NH3Replies: 9Last Post: 30-01-2009, 07:50 AM -
Parallel compressor problem
By dsltung in forum FundamentalsReplies: 21Last Post: 16-11-2008, 07:32 PM -
parallel flow condenser design for appliance a.c
By saurabh_23jan in forum Air ConditioningReplies: 2Last Post: 14-11-2008, 06:12 AM -
opinion on uneven parallel condensers
By Dimitris in forum Technical DiscussionsReplies: 2Last Post: 28-05-2008, 04:23 PM -
About parallel compressor system
By ernestlin in forum Technical SpeculationsReplies: 4Last Post: 13-09-2006, 03:34 AM
