Results 1 to 10 of 10
Threaded View
21-11-2009, 05:56 PM #1
GE Refrigerator GSS20IEPHWW Runs but stopped Cooling
Model: GSS20IEPHWW, Serial: MG283464, 5 years old.
History:
1. Problem started with the light going dim and the water would not dispense. Forums said to replace the main board. So I had the main control board (WR55X10552) replaced by GE a few months ago. Worked fine (should have done it my self to save money).
2. Then the water dispenser stopped. Reading the repair forums they say that moisture in the door foam may cause dispenser tube to freeze and that GE had a repair for it by installing the dispenser heater service kit (WR49X10173). I first tried adjusting the thermostats to a warmer setting to see where the water was freezing (I have some tubing for the water dispenser in the refrigerator side and it felt frozen). Then I unpluged the refrigerator and let it defrost manually (all day). There was a lite build up of frost on the rear panel inside the freezer and I did need to soak up some water as it defrosted. Worked fine for about a month.
3. It froze again (there was a build up of frost on the rear panel, I did not check the evaporator coil at that time). I let the refrigerator defrost again (unpluged all day) and it seemed like I had to soak up a few pints of water from the floor (drip pan was also full) as it was defrosting. Did some dust cleaning around the condenser/coil and fan under the refrigerator and checked the water tubes that I could see for leeks, none found.
I turned the refrigerator back on and set the thermostats, but the next morning it was still warm inside the refrigerator. Not having done anything to the refrigerator but cleaning I hit the forums to see what could be wrong. I checked the condenser fan under the refrigerator, it runs, checked the circulating fan in the freezer, it runs, but I do not hear the compressor motor running anymore. The refrigerator just stopped cooling. Testing to see if the main board was the problem I reinstalled my old board to see if it would start to cool again, but it does the same as the new main board. I opened the refrigerator panels and could not see anything visually wrong.
I did find a wire with a connector thats not connected to anything. Its coming out of the bottom of the refrigerator just above the condenser. Is it suppose to be connected to something (I can't find it) or is it a test lead?
What would cause the refrigerator to stop cooling after a manual defrost?
Can anyone help (foods getting warm), thank you.
GE Side by Side Runs but stopped Cooling
By EVESTAR in forum DomesticReplies: 3Last Post: 17-11-2008, 09:33 PM -
Energy saving Glycol filled dry cooler circuits
By Jasper in forum Technical DiscussionsReplies: 14Last Post: 19-06-2008, 02:18 PM -
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum IndustrialReplies: 5Last Post: 14-10-2005, 06:34 PM -
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM
