Results 1 to 8 of 8
Thread: de-super heaters
19-11-2009, 04:29 PM #1
de-super heaters
im a trainee and im trying to find out all i can about these de-super heaters....
dose anyone have like an idiots guied to them?? or explain what they are what they do?
cheers
19-11-2009, 05:12 PM #2
Re: de-super heaters
You may want to start here:
http://www.refrigeration-engineer.co...ad.php?t=19701
08-03-2010, 12:10 PM #3
De superheaters are used to lower the temperatures of superheated steam to the desired level by injecting the coolant via rapid heat transfer.
Highly efficient, rugged and proven systems designed to lower the temperatures of superheated steam within the shortest possible distance from the De superheater, via rapid heat transfer by injecting the coolant.
08-03-2010, 07:20 PM #4
26-09-2010, 03:33 PM #5
hi,
i am new to RE. i have a problem with my copeland compressor motor winding. model no d6rl2-2500-awm/d. can anyone help me. i want to get the motor rewound. thank you.
26-09-2010, 04:14 PM #6
Does this compressor have a de-superheater perhaps? If not, then you are most likely in the wrong thread.
26-09-2010, 10:53 PM #7
What i am going to say is not 100% factual, but enough for you to understand the basics.
To turn a low pressure gas (suction on a fridge system) to high pressure gas (discharge) you require power, this power ends up being heat, the discharge becomes highly superheated "hot" (sensible heat). A de-superheater, is a heat exchanger, that removes this sensible heat from the refrigerant, adding it to say water (heating the water) free heating!
How ever, you need to careful when selecting the heat exchanger, many now a days, select on the water heating side, and overlook what happens to the refrigeration system (I see to small heat exchanger installed where the head pressure increases, driving up input power and reducing net refrigeration effect)
26-09-2010, 11:40 PM #8
carrier 30gx oil separator heaters
By Coolie in forum Trouble ShootingReplies: 6Last Post: 12-05-2010, 05:58 PM -
seting super heat
By citytosurf in forum CommercialReplies: 21Last Post: 05-02-2009, 03:14 AM -
Flame Proof heaters for the drain pan
By smpsmp45 in forum NH3Replies: 2Last Post: 28-06-2008, 12:34 PM -
Crankcase heaters on splits?
By Makeit go Right in forum Air ConditioningReplies: 9Last Post: 12-06-2007, 08:16 PM -
Searle Evaporator Heaters
By Abe in forum CommercialReplies: 14Last Post: 31-12-2005, 10:24 AM
