    Feb 2007
    SIDE OF THE ROAD
    262
    Water flow rate.
    hi
    i am wondering is there an cheap instrument that anyone knows of for measuring water flow rate , ie through a condenser bundle @binder points...
    i suspect an uneven balance af flow from a large dry cooling cuircut causing abnormal temps and pressure on certain systems..
    any advice appreciated
    rgrds phil
    11,025
    Re: Water flow rate.
    I've never known a cheap instrument that does a good job and fortunately there have been very few in this line anyway.
    You can use a mechanical or electronic manometer of the type shown here...
    http://www.ttseries.com/sys/scripts/...wflow&type=wat
    Feb 2007
    SIDE OF THE ROAD
    262
    thanks brian
    11,025
    If it is for a one-off then you may be able to hire one, I know we can in England, BSRIA eg.
    Nov 2007
    Scotland
    67
    141
    If its Binder Test points you only need a needle type pressure gauge.Check the pressure drop across the Condenser bundle versus Manufacturers data.
    I bought a specific kit from BSS for I think £90 about 5 years ago.
  1. Flow Rate through Fan Coil Unit
    By deepu in forum Air Conditioning
    Last Post: 21-07-2009, 06:42 AM
  2. York Chiller evap water flow direction
    By mechillers in forum Technical Discussions
    Last Post: 30-03-2009, 05:37 PM
  3. Capillary Tube Characteristics
    By Chef in forum Fundamentals
    Last Post: 10-03-2009, 01:03 PM
  4. Water Chiller High Water Flow
    By assadp in forum Fundamentals
    Last Post: 22-05-2008, 06:41 PM
  5. Building a wine cabinet
