Results 1 to 2 of 2
    stugger's Avatar
    stugger Guest
    R404A P-h question
    Your home work for the week is to study a p-h chart for refrigerant R404a, and draw out the cycle (assuming 100% isentropic efficiency for the compression cycle). Detail the entry and exit conditions for the compressor, condenser evaporator and expansion device.
    Condition details to include:
    • <LI style="mso-list: l1 level1 lfo1" class=MsoNormal>Pressure. <LI style="mso-list: l1 level1 lfo1" class=MsoNormal>Temperature. <LI style="mso-list: l1 level1 lfo1" class=MsoNormal>Enthalpy. <LI style="mso-list: l1 level1 lfo1" class=MsoNormal>Entropy.
    • Fluid state.
    Refrigeration Cycle:
    • <LI style="mso-list: l0 level1 lfo2" class=MsoNormal>Evaporating temperature, -30OC. <LI style="mso-list: l0 level1 lfo2" class=MsoNormal>Condensing temperature, +40OC. <LI style="mso-list: l0 level1 lfo2" class=MsoNormal>Evaporator useful superheat, 5K. <LI style="mso-list: l0 level1 lfo2" class=MsoNormal>Non-useful superheat, 20K. <LI style="mso-list: l0 level1 lfo2" class=MsoNormal>Condenser sub-cooling, 5K.
    • Additional liquid sub-cooling, 10K
    Finally what is the refrigerant mass flow rate for the cycle 100, and what is isentropic efficiency?
    11,025
    Re: R404A P-h question
    Well, I suggest you get on with your homework then 'cos the the gibberish you have presented here will take some deciphering and we are not minded to do that.
    If you have a question to ask then please do so but do not expect study questions to be fully answered here, We expect you to do the work and we will comment on your answers or results.
  1. Max low side pressure in R404A system
    By Wilade in forum Technical Discussions
    Last Post: 25-08-2009, 09:23 PM
  2. Replies: 1
    Last Post: 02-06-2009, 04:01 PM
  3. R507 to R404a
    By Andy AC in forum Commercial
    Last Post: 09-08-2008, 05:36 PM
  4. Refriferation cycle question
    By ozmecheng in forum Fundamentals
    Last Post: 26-03-2008, 10:38 PM
  5. R134a or R404a
    By jingua_ph in forum Refrigerants
    Last Post: 27-09-2006, 03:31 PM
