    cool zab's Avatar
    cool zab Guest
    chocolate display problems
    Help lol.
    I am after some advice on a trimco chocolate display
    a zurich.
    The problem is with the chocolates drying out .
    the temp range is 14C and 17C cut in , the humidity was 23% to 60%. adv of 41%
    so i altered the hum stat and now a range of 32% and 75.5%. adv of 53.6% I did not alter the temp. But now the choc's are blooming.
    The system has a thermometer which controls compressor only.The humidity stat just controls the heater. Which is fitted with a overheat stat.
    Then a humidity stat which is sited just after the heater element.
    So Im after what are the best settings for this.cabinet and chocolates ..
    Thanks Guys
    Auckland
    74
    3,357
    37
    Re: chocolate display problems
    Hell I like chocolate.
    Have alot of process work experience with chocolate products.
    The major problem is cooling versus humidity, low humidity equals greying of product. Looks like a light brown color.
    The cooling coils need high sensible cooling and reduces moisture extraction, keep humidity levels at or above 75%. Pack off product in vacuum wraps or similar while chilled. New stuff lately is nitrogen purged pre- sealing.
    Aug 2009
    New Zealand
    55
    I had a blooming problem at a cake factory a while back. Try reducing the differential to 1 oC and control the humidity below 50%. Make sure the compressor isn't exceeding the maximum stop start reccommendations.
    cool zab's Avatar
    cool zab Guest
    kiwi, so what temp do you recommend. cheers zab
    Aug 2009
    New Zealand
    55
    The customer should be able to tell you what temperature they want. But as the case was originally set at 14-17 I would go for the 14-15 setting. If you go too cold, the choclates will sweat when served, and if it is too warm, they will be soft. Constant temperture is the most important thing
  1. Chocolate display fridge
    By danpitcher in forum Commercial
    Last Post: 12-04-2009, 09:30 AM
  2. Zoin Chocolate display case
    By Andy AC in forum Commercial
    Last Post: 04-05-2008, 02:02 PM
  3. samsung rs21dcns problems
    By slovenian ian in forum Trouble Shooting
    Last Post: 03-11-2007, 03:19 AM
  4. Display freezer problems!
    By cretan in forum Commercial
    Last Post: 23-07-2007, 12:37 AM
  5. chocolate display fridge
    By rbartlett in forum Commercial
    Last Post: 20-10-2004, 04:46 PM
