    jakerowl1's Avatar
    jakerowl1 Guest
    Calculate the duty of the condensing Unit
    Hi I'm new to the forum and relatively new to the trade, I'm doing an assignment at college this is the question,
    Calculate the duty of a condensing unit required to maintain the above ground beer cellar at 10 degrees c in an ambient of 27 degrees c. Take U value of the walls and ceiling 0.75 wm2 degrees c. The internal dimensions are 4m long x 3.5m x 2.5m high (ignore the concrete floor)
    which formula do i need to work this out, i obviously don't want the answer as that would be cheating,
    thanks Jake
    Feb 2008
    Las Vegas, NV
    67
    330
    Re: Calculate the duty of the condensing Unit
    jake,
    Try this link. There are manuals and programs available.
    http://www.hvacrinfo.com/loadcalcs.htm
    Thousands of HVACR manufacturers links! Visit: www.hvacrinfo.com
    jakerowl1's Avatar
    jakerowl1 Guest
    My problem is i need the exact formula not a calculator as i have to show my working out, regards
    11,025
    Although related to warmer climes than ours have a look at this PDF document which has lots of lovely calculations for you.
    Do a few to show that you know what you're doing then use software to speed the process.
    http://www.pdhonline.org/courses/m196/m196content.pdf
    edit: Sorry, lead in page to the above link..
    http://www.pdhonline.org/courses/m196/m196.htm
    JOCK992's Avatar
    JOCK992 Guest
    Hi Jake
    As you are still at college I was wondering if you, or anyone else out there would be able to help me at all with my engineering coursework??? Its about the role of an engineer. I have been through 3 refrigeration engineers who all seem to be letting me down so my work is unfinished - h e l p!!!
    yunus4u's Avatar
    yunus4u Guest
    what is double expansion could some one can explain me, how it will define,
    11,025
    Quote Originally Posted by yunus4u View Post
    It is used with steam engines where the high pressure steam having been used in the high pressure cylinder is then used in the low pressure cylinder, hence it is expanded twice.
    Please raise your question in a new thread in future, do not tag it onto someone else's thread.
  1. Thermo King OptiSet
    By REEFER-TEK in forum Transport
    Last Post: 06-12-2007, 07:23 PM
  2. Searle Condensing Unit
    By bernard in forum Commercial
    Last Post: 01-08-2006, 10:39 PM
  3. M I T S U S H I T A ac unit with no condensing unit
    By Chinua in forum Air Conditioning
    Last Post: 28-07-2006, 06:54 PM
  4. York/Bristol Condensing Unit
    By Abe in forum Commercial
    Last Post: 03-02-2003, 07:46 PM
  5. Matching Evaporator with Condensing Unit
    By Abe in forum Technical Discussions
    Last Post: 25-07-2001, 08:57 AM
