    Feb 2008
    New Zealand
    12
    Frick oil system
    Hi all, been a while
    Need to put a saftey valve on Frick oil cooler
    150psi saftey should be okay?
    PHE rated at 15bar working pressure but oil pressure should be around 3-4bar should it not?
    Unlike the Howden oil pressure which needs to be about 3bar above discharge
    Does this all sound right?
    Cheers Paul.
    Somerset
    69
    4,698
    Re: Frick oil system
    Quote Originally Posted by Loafa View Post
    Cheers Paul.
    Why do you need to fit one if there is not one fitted from new?
    Oct 2009
    Philippines
    I think the safety valve is to protect an equipment or operation, right ? THen the best is to find out the maximum pressure the equipment can handle and set the safety valve accordingly to a much lower pressure.
  1. Daikin fault codes
    By Chris2005 in forum Air Conditioning
    Last Post: 21-03-2012, 10:09 PM
  2. Ammonia Heat Pumps
    By US Iceman in forum New Technologies
    Last Post: 22-03-2010, 06:36 PM
  3. Fan model for system optimization
    By autt in forum System Optimization
    Last Post: 31-03-2007, 05:34 AM
  4. old frick system monitor
    By rasgrant in forum NH3
    Last Post: 17-01-2007, 06:15 PM
  5. Automotive A/C Vent Temp Range vs System
    By Don Browney in forum Air Conditioning
    Last Post: 15-05-2002, 06:19 AM
