Results 1 to 1 of 1
Thread: Help with heat exchanger?????
16-11-2009, 08:49 PM #1
Hi Guys
Does anybody knows how to calculate the thickness of a blind flange for the pressure test of a heat exchanger according to ASME VIII UG-99?, this because these are not standard flanges, they use 52 and 40 bolts Ø3/4”, and also, I’d like to know which kind of bolts I must use?fficeffice" />>>
Here I’m sending some information:>>
Test pressure: 450Psi.>>
Work substance: Water.>>
I attach drawing
I hope someone can help me .
Best Regards
Luis Sandoval
Some information on the aplication of suction gas/liquid line heat exchangers
By SteinarN in forum FundamentalsReplies: 5Last Post: 14-09-2009, 07:33 AM -
Basics or is it?
By Fett in forum FundamentalsReplies: 17Last Post: 10-09-2009, 01:45 AM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM -
heat exchanger for small chiller
By star882 in forum FundamentalsReplies: 4Last Post: 30-01-2007, 01:06 PM -
R134a <-> liquid heat exchanger design
By DaBit in forum Technical SpeculationsReplies: 19Last Post: 10-05-2002, 08:36 AM
