    GWalker's Avatar
    GWalker Guest
    Lightbulb Adsorption Chilling Waste Heat Recovery
    Can an adsorption chiller be used in a standard NH3 vapor compression refrigeration system before the condensers? The thought behind this is to use the hot NH3 gas to be the heat source for the adsorption chiller, which can then produce chilled water for other areas in the plant.
    If this is not feasible, what are the main hurdles?
    Any help on this would be greatly appreciated.
    38
    Re: Adsorption Chilling Waste Heat Recovery
    The idea probably has potential, depending on load profiles, utilizing common water cooling tower.
    The capital expenditure and recovery will possibly scare most clients off.
    Aug 2009
    New Zealand
    2,554
    I have often thought of a similar process, I would look a TVR system much lower capital cost. Not quite as efficient, but its a question of finding the balance. (all recovery options)
    GWalker's Avatar
    GWalker Guest
    Thanks for the replys Magoo and mad fridgie! I'll let you know how I get on.
  1. Capacity control
    By sparrow in forum Training
    Last Post: 18-01-2010, 07:49 PM
  2. Replies: 5
    Last Post: 14-09-2009, 07:33 AM
  3. Basics or is it?
    By Fett in forum Fundamentals
    Last Post: 10-09-2009, 01:45 AM
  4. frostles heat pump
    Last Post: 31-03-2008, 07:53 AM
  5. Heat recovery and aquifer heat/cold storage
    By RicHoe in forum Supermarket Refrigeration
    Last Post: 23-06-2006, 01:24 AM
Tags for this Thread
