Results 1 to 12 of 12
    Oct 2009
    8
    Ideal gas pressures
    HI,
    Can somebody please let me know the ideal refrigerant pressures High and Low for R407c, R410a, R22, R134a......
    11,024
    Re: Ideal gas pressures
    Depends what they are being used for.
    Oct 2009
    8
    non inverter AC systems and fridges
    3,853
    If you look at your gauges or better still get one of those slide rule thingies there will be a chart of pressures and temperatures. Change the temperature and the pressure will change also. Have a look at this and get a feel for how different evaporating or condensing temperatures will alter the presssures.
    So a room ac system cooling a room at 30C will have a different suction pressure to one running in a room at 18C.
    Your question is impossible to answer accurately without specific system operating conditions.
    I may well be wrong in guessing your motives for asking but there is no chart of correct pressure to see if a system is working ok. Its not that simple.
    Jul 2008
    London
    848
    ONE......HUNDRED......AND.........EIGHTY!!!!!!!!!!!!!!!
    opps sorry wrong forum..my bad
    May 2006
    India
    74
    399
    Varies with design conditions . However a compression ratio below 10 should be safe or ideal pressure.
    Oct 2009
    8
    Ok Thanks, I wasnt meaning an exact pressure and also I was meaning a fridge operating at 2 or 3 degrees, and an AC system controlling at 21 degrees for example.
    11,024
    As Monkey said above, use your PT tables to find the expected working pressures/temperatures.
    Jan 2008
    India
    70
    171
    For reading the pressure temperature chart you need the suction pressure and discharge pressure.
    And the pressure depends on ambient prevailing also.
    Feb 2008
    adelaide sth.oz
    1,015
    good onya multi your right,one woulds think that everything is related at different pressures to achieve evaporating temperature,
    triple top for me
    cheers
    Oct 2004
    uk
    57
    193
    Re: Gas pressures
    hi colsy welcome to fridges. for the reqired temp, use an evaporating temp/pressure about 10c lower than the temperature required. its a useful rule of thumb. regardless of the refrigerant used, the evaporating temperature will mostly follow that rule, so find the refrigerant you're interested in on a comparator, find the temperature you want the product to be stored at, reduce this by 10c and convert to pressure.
    et voila as they say in france; there you have it.
    Oct 2009
    8
    Re: Gas pressures
    Thanks for that bill, thats exactly whay I was asking to know.
  1. High suction and liquid pressures
    By bth0mas20 in forum Trouble Shooting
    Last Post: 28-08-2009, 08:32 PM
  2. Oil pressures
    By HeathT in forum Trouble Shooting
    Last Post: 24-02-2009, 08:32 PM
  3. Throttling and Ideal compression:
    By Bharath Rajes in forum Technical Discussions
    Last Post: 14-02-2009, 11:04 PM
  4. Pressures at Evaporating & Condensing Sides
    By stephen.t in forum Technical Discussions
    Last Post: 31-01-2008, 12:34 AM
  5. condensation pressures
    By abcdefg1675 in forum Refrigerants
    Last Post: 25-07-2002, 02:18 AM
