Thread: Help - small job plan needed..
15-11-2009, 01:42 PM #1
I have been given a job of fitting a hot gas defrost system to a remote freezer cabinet which has previously been fitted with electric defrost.
In order that I can complete this work as effectively as possible, please could I ask for your assitance on writing up a job plan/method statement that includes the following exclusive points:
* Type of tools needed
* Materials
* Equipement / Plant
* Operatives
* Time
Thanks for your help in advance!
Copple
15-11-2009, 02:30 PM #2
15-11-2009, 03:18 PM #3
15-11-2009, 07:31 PM #4
Re: Help - small job plan needed..
Not realy off topic is it?
it does sound very much like a project.
If you were given the job for real, can't you ask the person who gave you the job for advice?
Or you tell us what you have and maybe, just maybe others will help you out.
But you need to make the first step.
ozone.
15-11-2009, 08:40 PM #5
Why not compare the difference in systems with electric and hot gas defrost. Look them up in a book if you have no practical experience of them.
Then list the different components and control system and work out how you would get from one to the other and what you would use to do it.
Once you've done this post your proposal on here and i'm sure people will be happy to offer their constructive opinions.
There is a world of difference between doing someones job for them and helping them out
Monkey
16-11-2009, 09:33 AM #6
Look up in r.j.dossat for basic guidelines on hot gas defrost methods .
17-11-2009, 01:35 PM #7
Tools: all teh tools a refr. techs normally use and also the right tools to recover the refrigerant .
Material: copper , isolation, differential pressure valves, NRV's, end defrost thermostat,...
Equipment/Plant: what do you mean?
Operatives: same
Time: from 3 hours to several days. A hot gas defrost in a small bakery or in a huge supermarket.
What type of defrost: complete reverse cycle?It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
Autocascade refrigeration system: design verification needed
By DaBit in forum Technical SpeculationsReplies: 3Last Post: 07-02-2010, 07:48 AM -
crazy 3rd-world idea: aircon from small fridge
By lsemprini in forum FundamentalsReplies: 71Last Post: 29-05-2008, 01:10 AM -
Daikin 7kW Cassette +supply duct to small office
By Makeit go Right in forum Air ConditioningReplies: 6Last Post: 12-12-2007, 03:41 AM -
small copper pipe needed
By madmat252 in forum CommercialReplies: 5Last Post: 23-09-2006, 07:15 PM -
How many small strands needed to equal pipe pressure drop?
By DaBit in forum FundamentalsReplies: 17Last Post: 25-08-2003, 09:56 PM
