Results 1 to 41 of 41
17-11-2009, 03:18 AM #1
Re: Catastrophic compressor failure...need info
Without meaning to start a border war, how do PSM audits involve design reviews? The system should have gone through a HAZOP study, so if they missed something I could see how it would impact Hazardous Operations however...If all else fails, ask for help.
17-11-2009, 04:13 AM #2
To answer the question regarding PSM and design evaluations - you are correct we do not evaluate designs. The one thing that is expected of us is to ensure that the system is designed to good engineering practices (plain english - we read A LOT of standards - very exciting...). Thus if we find something that does not comply with design standards (e.g. ASME boiler/pressure vessels, API - american petroleum industry bulletins, etc) we have to require the employer to bring the system up to standard. A perfect example of this in ammonia refrigeration rooms is: IIAR and RETA all state that it is a good engineering practice to have quick stopping valves on oil drain pipes - we often find regular valves on these drain lines. We then site the industry recommendation and require the employer to install them. That is what I was attempting to get at by my messages - are additional traps really required outside of the LP accumilators - I REALLY appreciated the explaination that a trap is also referred to as the accumilator. When you are not in the business - it is hard to learn the Jargon on the fly. If the forum and the IIARs and RETAs would have told me that YES, it is a good engineering practice - and I determine they were missing from the system, then we would ask the employer to install them. I found this last post very helpful. Thank-you.
DORIN Comporessor Info Needed
By MikeySq in forum CommercialReplies: 6Last Post: 17-11-2009, 11:25 AM -
Catastrophic compressor failure..need info
By bsh3239 in forum CommercialReplies: 1Last Post: 15-11-2009, 08:22 PM -
Quartz crystal chiller info
By superswill in forum Trouble ShootingReplies: 2Last Post: 28-04-2009, 08:33 PM -
Daikin info required
By airconadam in forum Air ConditioningReplies: 5Last Post: 05-01-2009, 09:26 PM -
Need info on the shaft seal system for scotsman
By The MG Pony in forum CommercialReplies: 4Last Post: 17-03-2008, 02:02 AM
