    CRH's Avatar
    CRH Guest
    Question Pressure relief valves for freezers
    Hi, can some learned person tell me if there is an internationally accepted formula to determine the number of valves required for a particular sized room.
    Different valve manufacturers seem to use different formula with various constants.
    Thank's.
    Auckland
    74
    3,357
    37
    Re: Pressure relief valves for freezers
    Are you asking about pressure releif ports for enclosure, or refrig., system safety releif devices.
    CRH's Avatar
    CRH Guest
    Sorry, for enclosures
    Jun 2004
    Scotland
    56
    12
    I dont actually know the answer but suspect there are many different answers due to the variables involved. By that I suppose I mean assumptions. As you know the pressure relief valve is designed to equalize the internal pressure of the room to atmospheric pressure outside the room. Therefore it will depend upon the temperature differential ie room temp to ambient the more you cool the air the greater the pressure drop. It will probably also depend upon how much air is circulated, volume of air ingress into the room in proportion to the volume of the actual room. So there may be variations on room volume, room temperature, ambient temperature, door size, amount of traffic(air) in out of room. There is also the matter of defrosting how much heat is input into the room by the defrost heaters and what effect does that have on the internal pressure .
    I would have thought the only constant would have been the allowable pressure differential between the air in the room and the air on the outside before the room buckles or door blows open - but even here different panels, doors and latches may all have different ratings.
    And after all of that thinking my answer to your question is I am thankful that someone else has the ability to work it out because I wouldnt know where to start.
  1. Flooded Ammonia Part Two
    By Josip in forum NH3
    Last Post: 05-02-2009, 03:45 PM
  2. PT chart for different elevations
    By dkalasz in forum Tools and Calculators
    Last Post: 20-07-2008, 05:09 PM
  3. fun quiz
    By Brian23 in forum New to RE
    Last Post: 02-10-2007, 10:18 PM
  4. Liquid Overfeed Systems
    By US Iceman in forum NH3
    Last Post: 08-03-2007, 05:34 AM
  5. Replies: 31
    Last Post: 28-11-2006, 10:32 PM
