Results 1 to 10 of 10
    Reporter's Avatar
    Reporter Guest
    Electrolux 7831 - fridge too cold and noisy
    Wow, great web site, glad I've found it!
    I have an Electrolux integral fridge freezer (model 7831) which is about 7 years old. Recently the fridge has become way too cold (even with thermostat down to number 1), ice forms on the inside back wall.
    Also, it has become fairly noisy most of the time, sounds a bit like Darth Vader breathing!
    Was thinking about changing the thermostat but is it likely to be something more serious?.
    Thanks.
    Dec 2008
    UAE
    42
    171
    Re: Electrolux 7831 - fridge too cold and noisy
    Dear First Change the Thermostat then let us know if problem persists.
    I feel changing Thermostat will sove ur prob.also let the all frost melt down before restarting the ref.
    Amit
    Reporter's Avatar
    Reporter Guest
    Thanks for your reply.
    Do you really think though that the thermostat will stop the strange noises which are running almost constantly at the moment?
    I noticed last night if I turn the fridge off for about 30 seconds then turn it back on, even if I turn up the thermostat the fridge doesn't seem to make the noise (or start freezing) for a couple of hours.
    Really appreciate the help
    Jul 2009
    South Africa
    78
    195
    If you turn the fridge off and back on again in a short space of time you may damage the compressor. It's probably quiet after you do this because the overload safety has tripped and only resets after a period of time.
    When you say it sounds like Darth Vader, does it sound like him when he's just heavy breathing or is it more like him when he's fighting The Alliance Jedi Knights with his light saber?
    Reporter's Avatar
    Reporter Guest
    Definitely Darth Vader breathing heavily, or could be Dr. Who's tardis just getting reading for take off.....or an owl with laryngitis (my wife's idea, that!)
    Appreciate your help.
    May the force be with you my friend!
    Reporter's Avatar
    Reporter Guest
    I've spoken to the 'technical' people at Electrolux and they suggested I defrosted fridge/freezer, leave for 48 hours then restart as it may cure the problem......it didn't.
    From the noise I'm getting (which started again as soon as I restarted the fridge/freezer) - whooshing/gurgling sound every 30 seconds, makes me think it's not the thermostat.
    Other suggestions have been a problem with the compressor, is that something viable to fix or is it time to throw away and start again?
    Appreciate any help.
    Nessie's Avatar
    Nessie Guest
    Hi Did you solve this problem or end up getting a new fridge? I have an Electrolux integrated fridge freezer which is doing the same thing. It is also about seven years old.
    I would appreciate any help or advice.
    Feb 2011
    10
    Sounds like its running out of gas slowly doom !!! is it in a normal place i e your kitchen ? or the Garage if its Garage theres the problem !!! put it in the kitchen/ house ;-)
    Nessie's Avatar
    Nessie Guest
    It is in the kitchen. Can it be re-gassed and is it worth it?
    Nessie's Avatar
    Nessie Guest
    BTW looking at the number of people who have viewed this thread it sounds like a common problem!!
  1. Samsung RS21 DCNS Fridge too warm
    By Divekate in forum Trouble Shooting
    Last Post: 26-02-2007, 05:12 PM
