    Andrew Saint's Avatar
    Andrew Saint Guest
    Reducing expansion noise
    I am quite new to refrigeration design and have noticed various different manufacturers have specific ways to reduce the expansion noise made when the cap tube enters the freezer evaporator. Does anybody have any suggestions as to what they think is the best and most cost effective way to achieve the best noise reduction when joining the cap tube to the evaporator?
    Nov 2007
    London
    461
    Re: Reducing expansion noise
    you could try putty as this is quite dense or a little inline reciever.
    Jun 2005
    Romania
    213
    as brunstar says som putty cold solve the problem, and daikin in some applications use a lite incline receiver
    Jun 2004
    Scotland
    56
    12
    I seem to be asking more questions than giving answers but wondered what you mean by expansion noise? aso what kind of system are you talking about? My assuption was domestic freezers and the noise from the liquid evaporting and expanding into the evaporator. Is that so
    Mar 2009
    KZN, South Africa
    63
    2,212
    I've seen cork-tape used on cap tubes in a/c units. The tape is heavy & basically damps out the tube-based vibrations. It also seems to withstand cold & moisture fairly well.
    Andrew Saint Guest
    You are correct. I am talking about the noise when the liquid exits the cap tube into the evaporator on domestic fridges or freezers
  1. Weird noise
    By sandy1976 in forum Technical Speculations
    Last Post: 11-09-2009, 10:41 PM
  2. Actual Expansion Valve Process
    By AastroGuru in forum Fundamentals
    Last Post: 03-02-2009, 09:53 AM
  3. How an expansion tank works?
    By Raadster in forum Fundamentals
    Last Post: 25-07-2008, 02:25 PM
  4. Noise induced hearing loss damages
    By Abe in forum Legal-Business-Marketing
    Last Post: 26-05-2008, 10:36 AM
  5. Expansion
    By alesindo in forum Fundamentals
    Last Post: 30-07-2005, 09:16 AM
