Thread: Isothermic humidifier
28-11-2004, 02:42 PM #1
How do I calculate the rate of evaporation of a steam humidifier?
Never underestimate anybody, you never know when they will make you look like an idiot!
28-11-2004, 10:22 PM #2
Re: Isothermic humidifier
My first answer would be to read the instruction manual and the second would be to contact the manufacturer.
Or, you could monitor the water usage and go from there...or measure the up and down stream air conditions...Brian - Newton Abbot, Devon, UK
29-11-2004, 05:36 PM #3
Originally Posted by Brian_UKNever underestimate anybody, you never know when they will make you look like an idiot!
29-11-2004, 10:53 PM #4
http://van.hep.uiuc.edu/van/qa/secti...nd_Condensing/
Coolie, have a look at this, it may be of use to you or you may wish you hadn't started !Brian - Newton Abbot, Devon, UK
30-11-2004, 06:17 AM #5
Originally Posted by Coolie
Rog
01-12-2004, 04:51 PM #6
Will reply when I get home, where the info is.
Thanks for the interest.Never underestimate anybody, you never know when they will make you look like an idiot!
02-12-2004, 07:30 PM #7
The amount of steam depends solely on the heat you add to the water. This is a pure simple thermodynamical question.
Adding heat to let it boil and then adding further heat to vaporise the water.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
humidifier selection
By Krups in forum Air ConditioningReplies: 4Last Post: 14-05-2004, 08:52 PM -
Humidity
By frank in forum Air ConditioningReplies: 20Last Post: 30-12-2002, 08:06 PM
