Results 1 to 2 of 2
    emlotte's Avatar
    emlotte Guest
    Question (semi) Hermetic vs Open drive compressors
    I am looking for empirical evidence regarding mechanical (shaft) seal failures compared to motor burnouts. my experience is that over the past 15years I have seen 1 burnout and changed hundereds of shaft seals, but I need proof from an industry study of some sort. Can anyone suggest where I could go to get such proof.
    My client wants this before he purchases hermetic for the first time.
    Thanks for any help.
    Emlotte
    Sep 2003
    ISRAEL
    72
    4,248
    Re: (semi) Hermetic vs Open drive compressors
    I don't believe any one went to the trouble of making such a study.
    You should make a table with the "pro's" and "con's" for each type of compressor.
    Semi hermetic is cheaper in the long run, if the unit is properly built.
    Please note that semi hermetic compressor needs adequate cooling for the motor [the same goes for hermetic]
  1. Open Drive Compressor maintainance
    By jbomba in forum Training
    Last Post: 12-06-2009, 03:23 AM
  2. Compressors - screw or reciprocating?
    By Josip in forum Industrial Compressors
    Last Post: 27-01-2009, 10:36 PM
  3. do we need a hermetic or semi hermetic comp.?
    By duraid in forum Fundamentals
    Last Post: 17-04-2007, 05:52 PM
  4. Part Wound Semi Hermetic Compressors
    By bernard in forum Electrical
    Last Post: 22-12-2005, 06:33 PM
  5. Open Type Compressors
    By shogun7 in forum Air Conditioning
    Last Post: 07-01-2005, 09:15 AM
