Thread: SPlit System, no heat, no cool
04-11-2009, 03:29 AM #1
Hey guys, this is my first post here,
I have a small unit installed in my apartment, am having a few problems. It will start up on either heat/cool meaning the fan cycle begins, but when the actual heating/cooling is actuated, the power trips
Does this sound like a common fault?
Also, this only began in winter, and i could sorta get it to work some times, but then it would power trip every time, and now summer is here, it trips on the air cond side aswell.
Im hoping it will be some kind of component that needs replacing
04-11-2009, 04:03 AM #2
Re: Split system, no heat no cool
Get a refrigeration service tech., to check system.
Sounds like an electrical issue if tripping supply, do not get an electrician, do not get a plumber, get some one that knows heat pumps. A "refrigeration engineer ".
04-11-2009, 06:47 AM #3
Most likely one of the motors is stuffed, or there's a loose connection somewhere.
In Oz, you MUST be licenced to work on this equipment. Please don't try DIY, you may very easily hurt yourself very badly.
What area of Oz are you in? with a bit of luck,one of us members may be reasonably close by, or know someone close to you we can recommend.
04-11-2009, 11:48 AM #4
lives south by the sound of it
04-11-2009, 01:07 PM #5
Cheers, ok ill have a techiw round soon, unless you guys could recomend one, ah cheers guys
heh, yup, adelaide mate yous correct, howd you guess?
04-11-2009, 05:18 PM #6
kubsnax, it must have been your strong acsent,
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
Domestic Heat Pump System
By jameswilson in forum Heat PumpsReplies: 27Last Post: 04-01-2010, 08:36 AM -
indoor split ice
By SkyWalker in forum Air ConditioningReplies: 5Last Post: 07-09-2009, 04:51 PM -
How good is your split system running?
By acnerd in forum Air ConditioningReplies: 18Last Post: 05-08-2009, 07:35 PM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM
