04-11-2009, 11:15 AM #1
Which way up should the dessecant drier go?
We are designing a capiilary system, and we are putting a dessecant drier in-line between the condensor and the capillary tube.
On some installation i've seen the capillary laid horizontally, but I've also been told that the capillary should have the capillary inclined up with the capillary outlet end pointing UP to get a liquid seal on the inlet to the drier.
Other things I've read (and images of some products on the web) suggest that the drier should point DOWN, to ensure a liquid seal over the inlet end of the capillary (stops vapour refrigerant going into the capillary which is bad).
What's the correct oientation of the drier?
Thanks.
a newbie
04-11-2009, 11:18 AM #2
04-11-2009, 11:37 AM #3
Re: Which way up should the dessecant drier go?
who cares as long as the charge etc is correct but vertical is preferable.
skolmmm to beer or not to beer...........lets drink breakfast
04-11-2009, 12:05 PM #4
vertical eh? outlet (capillary end) up or down?
04-11-2009, 12:36 PM #5
Capiliary out at the bottom, feed from condenser in at the top imo.
10-11-2009, 05:44 AM #6
Dont think it makes much of a difference, if anything we fit the drier at an angle with the capillary out the top.
10-11-2009, 06:21 AM #7
Cap end (drier outlet) down.
11-11-2009, 01:26 AM #8
23-11-2009, 10:05 PM #9
Dryer outlet facing down and capillary coming out the bottom, this is to get the vapour seal as you mentioned over the capillary. I've been told that vapour in a capillary line can cause turbulance and act as a blockage to some degree.
I have seen dryers upside down though and everything seemed to be working fine.
Still if a jobs worth doing...
burn out drier
By mcunliffe4 in forum CommercialReplies: 1Last Post: 16-09-2009, 11:04 PM -
Filter Drier
By grego in forum New TechnologiesReplies: 6Last Post: 30-05-2008, 08:32 PM -
suction line drier.
By Joeheath in forum Air ConditioningReplies: 5Last Post: 10-04-2008, 08:59 PM -
Shelf life of an uncapped dessicant drier.
By eberg in forum Air ConditioningReplies: 2Last Post: 22-08-2001, 01:22 PM -
Drier Position
By subzero*psia in forum CommercialReplies: 8Last Post: 23-07-2001, 10:28 PM
