Thread: Titanium Heat Exchanger
02-11-2009, 01:46 PM #1
I have a titanium heat exchanger which serves as the evaporator on a chiller. I am cooling water for an exhibit. There is a refrigerant leak on 3 of the lokring compression fittings that joins the titanium tube and copper tube. Lokring company says I need 1 1/4 inches of tube left to use another fitting because they have a special tool that makes the compression. I only have 3/4 inches left. Any other suggestions or fittings I could use out there? The titanium and copper tubing is 3/4 inch. I would hate to have to buy a new titanium heatexchanger.
02-11-2009, 07:10 PM #2
- Join Date
- Sep 2009
- Location
- Iran
- Age
- 66
- Posts
- 672
- Blog Entries
- 1
- Rep Power
- 19
Re: Titanium Heat Exchanger
Why you do not use welding to make it longer ( titanium tube) .or can you use normal flaring (copper flaring)
03-11-2009, 07:38 AM #3
Welding with at least 40%Ag
04-11-2009, 11:40 AM #4
peters got it!tried to add to your rep are you guys immune to such treatment?
mmm yummy cheersLast edited by lowcool; 04-11-2009 at 11:42 AM.
Some information on the aplication of suction gas/liquid line heat exchangers
By SteinarN in forum FundamentalsReplies: 5Last Post: 14-09-2009, 07:33 AM -
Basics or is it?
By Fett in forum FundamentalsReplies: 17Last Post: 10-09-2009, 01:45 AM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM -
heat exchanger for small chiller
By star882 in forum FundamentalsReplies: 4Last Post: 30-01-2007, 12:06 PM -
R134a <-> liquid heat exchanger design
By DaBit in forum Technical SpeculationsReplies: 19Last Post: 10-05-2002, 08:36 AM
