01-11-2009, 08:18 PM #1
Zanussi ZNB 3850 Fridge warm, freezer cold
I seem to have a common problem. This morning my 2.5 year old Zanussi ZNB 3850 Fridge-Freezer had a fridge temperature of 16 degrees celsius (i.e warm!) and a normal freezer temperature of -20 degrees celsius. Freezer seems to operate normally but the fridge will not cool down. The compressor switches on and off and gets pretty warm (not sure if abnormal). I can feel a very warm spot on the lower back panel of the fridge. Interestingly the high temperature symbol mentioned in the manual does not appear. Defrost water drain is not blocked. What can I do? Please help!
02-11-2009, 12:47 PM #2
Re: Zanussi ZNB 3850 Fridge warm, freezer cold
My Recommendations,
1. Switch off the unit for 3~4 hrs
2. After that Check for Eva Fan Running OK ????
Run the unit and if again problem faced then get bk to us.
Amit
02-11-2009, 10:05 PM #3
Thanks. Have switched the unit off and will let you know what happens when I turn it back on.
Zanussi ZENB9950 Freezer cold fridge not
By fkarim7 in forum DomesticReplies: 3Last Post: 03-09-2009, 09:10 PM -
Indesit FROST FREE Fridge Freezer - fridge not cold
By pauby in forum DomesticReplies: 26Last Post: 09-03-2009, 11:04 AM -
Belling Fridge warm, Freezer cold, please help.
By beuwy in forum Technical DiscussionsReplies: 0Last Post: 04-03-2009, 01:42 PM -
Zanussi zebf 249n fridge warm, freezer cold
By davemar in forum DomesticReplies: 4Last Post: 18-03-2008, 08:58 PM -
Zanussi - fridge is warm but freezer is cold.
By Bob Ball in forum Trouble ShootingReplies: 2Last Post: 11-02-2007, 04:59 PM
