Thread: mineral oil
    oonal's Avatar
    oonal Guest
    Exclamation mineral oil
    Dear all,
    We has been using mineral oil in our ammonia compressors, we want to use "so" due to mo's poor performance.
    Can we use syntetic oil in our systems, create some problems ? ( Leakage etc.)
    Somerset
    69
    4,698
    Re: mineral oil
    Quote Originally Posted by oonal View Post
    Dear all,
    Oonal.
    Please take advise from your supplier as you can use certain Synthetic oils in a system that has previously had mineral in it.
    But beware as a lot of them have a cleaning agent / properties.
    This can lead to various issue that have been discussed at length on the forum before.
    If you fit the wrong oil you will have all sorts of issues.
    So play safe and seek expert advise.
    From experience it is beneficial to change over
    As oil consumption ( less carry over) and therefore the amount you use are both significantly reduced.
    Jul 2007
    Czech
    61
    374
    Re: mineral oil
    Good to write what the compressor and oil you use
    3,357
    Re: mineral oil
    I think synthetic oil is overated , especially mobil .
    Unless you can get it at a very good price , why bother .
    Pennsylvania
    113
    Re: mineral oil
    Last year I had problems with a system concerning oil. Essentially after 6 months the oil would rapidly rise in viscosity from ISO68 to ISO90. We eventually resolved this issue with the use of 5 micron absolute filters and the replacement of the mineral oil with a Frick synthetic. I've not seen a viscosity increase in the new oil in over a year and the particle counts on our oil samples are greatly improved. Frick was easy to work with even though this system did not use Frick compressors.
    Oct 2009
    USA Fort Worth
    5
    Re: mineral oil
    Howdy,
    If you are using napthenic mineral oil and you decide to change to a mineral hydrotreated parafinic or synthetic oil, it is advisable to change the neoprene seals & o-rings as the napthenic oils cause the elastomers to swell. When the new oil is introduced it will allow the elastomers to shrink back down close to their original size and MAY cause leaks.
    To my knowledge there are two basic types of sythetic oil; Alkybenzene and polyalphaolefin. I do not know how either of these would interchange with a napthenic oil, but I do now if it is AB the elastomers would possibly shrink here as well when used with a hydrotreated parafinic oil.
    When switching oil brands it is always a good idea to completely drain the separators and clean out as much of the old type oil as possible, even if it is the same type oil.
  1. R422D Oil return problems !
    By kfjoe in forum Technical Discussions
    Last Post: 26-08-2010, 02:11 PM
  2. Replies: 4
    Last Post: 07-03-2010, 02:15 AM
  3. Running R404a with mineral oil.
    By Brettox in forum Technical Speculations
    Last Post: 01-10-2009, 08:18 AM
  4. what is the best blend for low temp
    By tony_rich in forum Refrigerants
    Last Post: 05-08-2006, 08:29 AM
  5. Oil changeover from mineral oil to POE in compressor
    By aygul in forum Technical Discussions
    Last Post: 15-03-2003, 04:02 AM
