Results 1 to 2 of 2
Thread: control valve?
    Oct 2009
    usa
    59
    7
    control valve?
    hey, i am working on an old milk truck with these truck plates for cooling. on the piping to these plates, is what looks like maybe a three way valve? anyhow, it has a small diameter tube coming from the top. at the other end of the tube is a bulb. Question; what does this valve do and the bulb has broken off from vibration. will this affect operation or should the bulb be brazed back on? does the tube contain a gas or a vacuum? its hard to red numbers from the top of the valve but a number 8448 is visible. the fridge compartment has valves that look the same and rcd 1/4 fw r12 8431 can be read on the tops.
    thanks
    Feb 2008
    adelaide sth.oz
    1,015
    Re: control valve?
    gday garth
    i would say its a thermostatic expansion valve.that bulb is the thermo bulb measuring suction line(evaporator) temperature allowing valve to regulate the flow of refrigerant.by the numbers it may be a sporlan valve but replacement will require a reprocessing of the system.in short the valve is stuffed and your gonna need a fridgy.
    cheers
  1. Head Pressure control valve
    By Lertpol in forum New Technologies
    Last Post: 27-04-2010, 11:24 AM
  2. calibrating slide valve on rxf control pannel
    By marley in forum Industrial
    Last Post: 30-08-2009, 06:26 PM
  3. LEV does not open
    By Yuri B. in forum Air Conditioning
    Last Post: 19-07-2009, 02:37 PM
  4. Control scenario
    By Mike Hopkins in forum Technical Discussions
    Last Post: 14-09-2007, 11:25 AM
  5. New Capacity Control Solution
    By embrown in forum New Technologies
    Last Post: 30-12-2003, 01:33 PM
