    Feb 2002
    Brazil
    58
    26
    Question Saturation temperature
    There is an industrial refrigeration installation with ammonia in a place where the altitude is 1000m above the sea level. The manometric pressure in the liquid separator 0,19MPa.
    So all Refrigerants Thermophysical Properties Tables are in absolute pressures what´s the ammonia saturation temperature in this case?
    Regards.
    Volnei
    3,357
    Re: Saturation temperature
    Not sure why you need to convert as once system has ammonia in it and sealed up atmospheric pressure won't effect it in anyway ?
    If you have absolute reading subtract 0.1 mpa for gauge reading .
    ie atmospheric pressure at sea level + 101 kpa or 14.7 psi for absolute reading .
    Maybe you can also adjust readout to gauge if you have a frick or similar control panel .
    Mar 2009
    U.S.A.
    320
    Unless that's a differential gauge: Your atmospheric pressure will have nothing to do with the reading, or with the Sat Temp corresponding (As ranger staates). The answer i s Minus 20 C. is corresponding Sat Temp.
    Auckland
    74
    3,357
    37
    Has nothing to do with altitude, the reference relates to absolute conditions as a standard.
  1. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
  2. Superheat and Subcooling
    By Chunk in forum Fundamentals
    Last Post: 15-01-2011, 01:24 AM
  3. LG heat pump problem
    By back2space in forum Heat Pumps
    Last Post: 01-02-2009, 11:23 PM
  4. TK basic micro-p features and functions
    By REEFER-TEK in forum Transport
    Last Post: 05-12-2007, 06:25 PM
  5. Article in ACH&R News
    By Gary in forum Fundamentals
    Last Post: 20-05-2003, 12:27 AM
