Results 1 to 8 of 8
Thread: r-12 to ?
    Oct 2009
    usa
    59
    7
    Question r-12 to ?
    have an old milk truck with a separate fridge and freezer. apparently has a low charge, been sitting for 12 years. question. can i evacuate and replace with r-134a? being a refer dumb-dumb would anyone know if this makes sense?
    3,856
    Re: r-12 to ?
    Hi Garthr,
    R134a won't be compatable with the oil and o rings used in your old system. What you need is a refrigerant designed to replace R12 in existing systems such as R413A also know as R49 or I believe there is one called 'hotshot' in the states. Have a talk with your local rerigerant wholesaler to see what they stock and recommend.
    Jon
    Oct 2009
    usa
    59
    7
    Re: r-12 to ?
    thanks for the reply. i have heard of a replacement refrigerant for r-12 called freeze 12 for automotive use. would this perhaps be a satisfactory substitute for r-12 without component damage and without having to change the oil??
    3,856
    Re: r-12 to ?
    I've not heard of freeze 12, personally i wouldn't use any refrigerant that didn't have an 'R' number.
    What R12 replacements does your local fridge wholesaler stock?
    Just had a quick look online, RS24 or R426A might be worth a look, all the other blends listed in the US EPA list seem to still hcfc's in them, which are being banned here in december, not sure how far behind things are in the States.
    Petur's Avatar
    Petur Guest
    Re: r-12 to ?
    i have been asked to replace r12, normally that is 134a and change of oil etc.
    but if i want to retain the plant as is, what refrigerant can be suggested
    bstrgds
    Sep 2003
    ISRAEL
    72
    4,248
    Re: r-12 to ?
    R-409 is a replace for R-12.
    I have used it a lot and it is doing very good job.
    You work above 0°C so you will not have any problems.
    mikrasiates's Avatar
    mikrasiates Guest
    Re: r-12 to ?
    R409 my friend it is good
    Aug 2009
    85
    15
    Re: r-12 to ?
    use r 49+ , EASYstraight foward , no messing about with oil change . just recover any existing refrigerant , change drier , pressure test . vac out system if pressure test passes , and recharge .we ,ve done 100,s on r49 and now on r49+ .
