Results 1 to 1 of 1
23-10-2009, 08:23 PM #1
R22 to R417a or R422d succes or failure?
Hi My name is Mark. I have returned to work in the UK after being inBrsbane australia the last 8 years. found out R22 is to go soon and my new company is getting enquirie about retrofit to R417a or R422d. DuPont claim 'O' rings and elastomeric seals will most likely leak after retrofit. has anyone experience of retrfits to the above?? did they leak?? did you change seals etc?. I have to submit quotes and do not know likelihood of leaks..
Carrier Transicold Container Problem
By Shamel in forum TransportReplies: 39Last Post: 23-01-2012, 11:23 PM -
R 417 A direct replacement of R 22
By abbasi in forum RefrigerantsReplies: 28Last Post: 08-09-2011, 12:47 AM -
Repeated tubes failure in absorption chiller unit
By nostalgia in forum Trouble ShootingReplies: 5Last Post: 17-08-2009, 06:35 AM -
5H86 Failure Investigation Results - Comments Wanted
By 5H86User in forum Technical DiscussionsReplies: 2Last Post: 17-07-2009, 01:52 PM -
Compressor failure...... cause
By herefishy in forum Technical SpeculationsReplies: 8Last Post: 06-12-2002, 12:15 AM
