    Dec 2006
    Indonesia
    74
    37
    Question about calculating compressor power
    Hi all, I am from Indonesia..
    I'd like to cool a 500 litre water down to 3 degrees Celcius, how big of a compressor do I need? How many BTU? Roughly how much time needed to reach that temperature from, let's say, 32 degrees celcius?
    Basically I wonder if there is a simple formula to calculate it?
    Thanks, all answers are appreciate it.
    If you dont mind, just email me at ysh1317@cbn.net.id.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Question about calculating compressor power
    Q = m cp dt
    m = mass flow
    cp = specific heat of water
    dt = temperature gap
    the mass flow is the quantity of water in time. Basicly, there's a difference in power to cool down 500 liters of water in 1 minute or 1 hour about that is 1 to 60.
    Therefore, in metric units, for a cooling time of 1 hour.
    Q = 500 Kg/h x 4.2 kJ/Kg K x 27 K = 56700 kJ/h = 15.75 kJ/s = 15.75 kW = 53.7 MBTU/h
    Auckland
    74
    3,357
    38
    Well put and simply explained "nonickname ", at +3.0 ' C water I would recommend an icebank if not using glycol.
    Aug 2009
    New Zealand
    2,554
    26
    Spot on "nonickname"
  1. Replies: 1
    Last Post: 02-06-2009, 04:01 PM
  2. Heat Transfer Exam Question
    By alexdouglas1969 in forum Fundamentals
    Last Post: 13-12-2008, 04:19 PM
  3. Refriferation cycle question
    By ozmecheng in forum Fundamentals
    Last Post: 26-03-2008, 10:38 PM
  4. r134a question, calculating heat lost by refrigerant
    By kamikazi929 in forum Fundamentals
    Last Post: 03-01-2008, 08:19 PM
  5. Urgent, Kirchoff question
    By Peter_1 in forum Fundamentals
    Last Post: 20-01-2004, 03:12 PM
