Results 1 to 10 of 10
    Nov 2008
    wakefield
    74
    28
    Smile serve over chiller
    would like to know how to chang temperature setting on serve over display cabinet,buttons at left hand are arrow pointing upwards and arrow pointing downwards,at right arrow pointing straight right and snowflake symbol.Problem is drip tray at top is freezing solid then overflowing.Thanks
    11,024
    Re: serve over chiller
    Any name on the display itself?
    LAE, Eliwell, Dixell etc
    Nov 2008
    wakefield
    74
    28
    Frilixa,But that could be seller rather than manufacturer
    Auckland
    74
    3,357
    38
    Folco.
    sounds like the condensate drain is blocked, and if icing drain tray up, then set point on chiller is too cold.
    Does controller have a set button?.
    try www.frilixa.com
    Nov 2008
    wakefield
    74
    28
    no set button,just buttons as described in previous post.thanks for reply.
    Auckland
    74
    3,357
    38
    Hi Folco.
    Sounds like a re-badged Danfoss EKC controller, but then I could be wrong, quite often the case.
    Did you try and clear the condensate drain?.
    Did you check the web site suggested?.
    Try and hold both up and down arrows at same time for period of say 5 seconds, and what happens.
    Nov 2008
    wakefield
    74
    28
    yes,cleaned out drain hole.Will try holding both buttons,thanks for your help.PS bottom setting at 4 degrees,top at 6,is this ok?
    Auckland
    74
    3,357
    38
    Hi Folco.
    sounds about right, could be a case that the controller relay has failed closed and keeping the unit cooling, hence freezing problem.
    I will see if I can find and send to you a set-up brochure. Can anyone else help with this, open question.
    martin
    Nov 2008
    wakefield
    74
    28
    does go off and into defrost mode then back on regularly
    Nov 2008
    wakefield
    74
    28
    holding buttons for 5 seconds worked ok.thanks for info
  1. process chiller help
    By talon771 in forum Industrial
    Last Post: 12-01-2011, 08:42 PM
  2. Absorption Chiller VS Mech. Chiller
    By Intern in forum Industrial
    Last Post: 30-05-2009, 08:31 AM
  3. York Chiller startup when on Emergency Power
    By Apollo10 in forum Trouble Shooting
    Last Post: 22-12-2008, 07:13 PM
  4. Trane CVHE 450 R11 Centrifugal Chiller
    By albertjoseph in forum Air Conditioning
    Last Post: 06-10-2008, 03:23 PM
