20-10-2009, 03:34 PM #1
Argh! 507 system charged with 404A... expected problems?
Ive got a multideck thats been charged with 404A after a compressor change. have just found out that origional manufacture used 507 in the system.
Its been working fine for the last 3 weeks now, but can i expect any probelms? Different oils? Different charges?
Cheers!
20-10-2009, 04:06 PM #2
Re: Argh! 507 system charged with 404A... expected problems?
The oils will be the same, i think R404A is R507 with a bit of R134a mixed in. R404A txv's are marked up to work with R507 as well. So my money would be on ok, but i don't know for sure
20-10-2009, 04:21 PM #3
20-10-2009, 04:29 PM #4
Confirmed.
20-10-2009, 05:38 PM #5
No problems. The properties of this gas mix will be in the middle of R507 and R404A, and this two blends have almost the same composition and properties.
20-10-2009, 05:57 PM #6
Phew!
Thanks very much for so many good replies!
Daikin fault codes
By Chris2005 in forum Air ConditioningReplies: 45Last Post: 21-03-2012, 10:09 PM -
System Burn Out Troubleshooting
By altaf22m in forum Technical DiscussionsReplies: 13Last Post: 07-05-2010, 09:24 AM -
Burn out System, Clean up procedure. & Troubleshooting.
By altaf22m in forum CommercialReplies: 19Last Post: 15-04-2008, 07:03 PM -
how do i know my system is charged well
By duraid in forum FundamentalsReplies: 19Last Post: 29-09-2005, 07:27 PM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM
