Results 1 to 15 of 15
    May 2006
    Sussex
    362
    21
    Armaflex cracking a bit ~ Paint it?
    One of our customers has some armaflex on external runs (about 45m total), which is starting to crack from UV/sunlight. The first thought from our engineer was to paint it with two coats of Armaflex paint to preserve it/protect it from getting worse.
    Has anyone done this and recommend it as a good way to go?
    Presumably, it would stop further UV/sunlight damage but I was wondering how long it would last before another application would be needed.
    The better alternative might be just to do it properly with HT-Armaflex, which is better against the elements, yes?
    Jun 2009
    East Anglia
    38
    204
    15
    Re: Armaflex cracking a bit ~ Paint it?
    Cant remember xactly but im sure last time i went to the wholesaler they had some big promo about the lastst developmnt in armourflex being a new foam that was resistant to all weather and also had some sort of anti bac property that ment it wouldnt turn green/brown
    hookster's Avatar
    hookster is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2007
    Hampshire
    438
    32
    I have tried the painting route and the armaflex paint is messy expensive and difficult to apply.
    I would recommend a PIB covering which is bonded with white spirits.
    You can get it in different colours too!!
    11,024
    I'll go along with Hookster's idea, PIB covering will do the trick.
    Product link here...
    http://www.cmsacoustics.co.uk/ind-ac...B_Sheeting.htm
    Sep 2003
    ISRAEL
    72
    4,248
    Any exterior plastic[water] based paint will protect it.
    I do it for the past 20 years.
    Split Croatia
    57
    6,151
    36
    I usually wrap it with aluminum self-adhesive tape.
    Apr 2009
    Australia
    61
    30
    Using a light gauge sheet metal(colourbond) capping is not that uncommon either. You can get in folded to size from any sheet metal workshop in various colours.
    Oct 2008
    Australia
    210
    Id paint it, its quick, cheap and easy. Also lasts quite a long time.
    May 2006
    Sussex
    362
    21
    Hi, Rude. When you do it, any experiences on how long it lasts before another application would be needed? ie does it need re-painting after 3-4 years, or last longer/less than that?
    Oct 2008
    Australia
    210
    It depends how much sun/rain it gets but generally about 5 years. We use aerocoat which is made to be put onto aeroflex and dont have many problems with it.
    http://www.aeroflexusa.com/products/aerocoat/
    May 2008
    170
    Armaflex is supposed to be painted as soon as you install it outside or UV light damages it.
    I seem to be the only contractor in the UK who paints AC pipes.
    We have a customer whose lagging was deteriating so we painted it last year. I was on site the other day and the paint has preserved it.
    I would paint it, it will be cheap and realistic for the customer.
    May 2006
    India
    74
    399
    I wish to use hoses/ braided flexible pipes for pr gages & controls . Refrigerant is r-404a / r-407c .
    What should be the material of construction for these pipes as the non-cfc refrigerants react with hoses & at times hoses leak out & noted to be bulging .
    May 2006
    Sussex
    362
    21
    Thanks for the tips and ideas.
    We painted it. We had the order and it was not easy to go back to re-sell them on the more expensive job of replacing it all with the HT-Armaflex, or maybe PIB etc.
    I do not know how long the HT product has been around but it seems stupid to install the internal spec material on external pipework, especially where it is exposed to lots of sunlight/UV and needs painting immediately or within 2-3 years -- it's not fit for the purpose in that case. Now the HT-Armaflex is on the market, we all should install that on external pipework when the system goes in, rather than use the 'internal' stuff.
    Having said that, I tried many distributors/suppliers for the HT-Armaflex (in case we could possibly re-lag for a similar price) but they do not stock it - just the internal stuff. They could get it in for me, though. If I wanted some, I would need to special-order it by the box (150m-odd each box…times the 3-4 different pipe sizes too! Mega). That seems to be the main force behind any misuse of internal Armaflex on external pipework. On a 15m split run, you’d have to buy two 150m boxes of the stuff.
    However, after many phone calls and internet searching, I did eventually find one supplier who sold it by the 2m length, at just a few pennies more than the internal...........not so much more expensive that an installer could honestly say it was too expensive to install, especially if you have to paint the internal stuff to use it externally.
    Getting back to this paint job, the insulation was 2-3 years old and was showing small cracks in the surface. Not just the pipework facing the sunlight but also a shaded elevation where the sun don’t shine. Odd that it was suffering the same fate as the lagging in the sunlight. Anyway, after releasing most of the cable-ties, the paint went on well (applied thickly). Applied 2-coats, though some got an extra 3rd helping, to be sure to be sure; then re-fixed cable-ties. It looked like it was worth doing, and will probably prolong the life of that insulation for a few extra years.
    May 2008
    101
    Its UV that breaks down the cell structure of standard Armaflex. Painting will give some form of protection but for the best solution HT Armaflex is the way to go. It has been manufactured with the solar energy market in mind and is therefore able to withstand much higher temperatures and it is UV resistant. The anti fungus type ingredient in Armaflex is Microban.
    http://www.pipelagging.com/high-temp...tion-c-55.html
    Oct 2007
    jersey channel islands
    186
    i have found armafex paint to be quite good , another thing that we have tried and works is green house shadding, a fine plastic mesh, keeps the birds off as well, mind you they dont seem to like painted lagging
  1. Stress Corrosion Cracking in NH3 Vessels
    By US Iceman in forum NH3
    Last Post: 15-02-2008, 06:41 PM
  2. Paint Shop Ventilation
    By hlacviet in forum New to RE
    Last Post: 09-08-2007, 11:13 PM
  3. Paint shop heat transfer
    By nh3simman in forum Fundamentals
    Last Post: 19-04-2007, 01:44 AM
  4. Birds damaging Armaflex
    By Makeit go Right in forum Air Conditioning
    Last Post: 24-03-2007, 12:16 AM
  5. ventillation system for paint shop
    By abbasi in forum Fundamentals
    Last Post: 17-02-2006, 10:59 AM
Tags for this Thread
