Thread: cub tube for r23
13-11-2004, 02:22 PM #1
cub tube for r23
hi
could you tell me how to choice a tub cube for R23 in a cascade system, thanks
14-11-2004, 09:26 AM #2
Re: cub tube for r23
Wha is a tub cube?
Do you mean capillary tube?
PeterIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
15-11-2004, 02:14 AM #3
sorry, My mean is capillary tube
15-11-2004, 06:54 AM #4
Re: cap tube for r23
There may exists software programs for this and there exists even formulas for this (Stoecker for example has them in his book Refr & AC) but we did it with trail and error. (We hadn't these formulas in the past)
Started with the cap tube tables we got from R502 with +/- the same pressure drop and cut the capillary somewhat longer. Installed a shutoff valve before the cap tube and a schraeder on the evaporator so that we could retract the gas and evacuate after each trial.
In the formulas, you need certain numbers like Friction factor, Reynolds number, fraction of vapor mixture of liquid and vapor, viscosity of saturated liquid and saturated vapor,... in my opinion, not that easy to find.
It takes +/- 3 pages of formula's in his book.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
oxidation scale in copper tube and fittings
By DeB in forum FundamentalsReplies: 8Last Post: 23-06-2006, 09:45 PM -
metric capillary tube
By tralex in forum FundamentalsReplies: 5Last Post: 21-02-2006, 06:57 AM -
The amazing Mr. Cap Tube
By shogun7 in forum DomesticReplies: 52Last Post: 07-01-2006, 07:33 PM -
Tube staggered/squared
By bersaga in forum FundamentalsReplies: 2Last Post: 05-01-2003, 11:56 PM -
coaxial (tube in tube) heat exc.
By aliugur in forum FundamentalsReplies: 0Last Post: 04-06-2002, 08:23 AM
