Results 1 to 2 of 2
    Sep 2008
    Melbourne, Australia
    8
    Fujita Air Conditioner
    Hi all,
    Some advice. I have a Fujita A/C which runs fine on the cooling cycle, but on heating the condenser fan starts up then the indoor fan runs for a few seconds and then cuts out. Any ideas as to the cause? The unit was recently vacuumed and recharged and the filters have all been cleaned after which it ran fine for abpout a day but it is cycling again. No signs of any leaks in the system or faults with the compressor, etc. When it was first serviced the port pressure was around 2,000 kPa but it now cuts off at just under 1,600 kPa.
    Thanks for any suggestions.
    Apr 2006
    stafford
    42
    974
    Re: Fujita Air Conditioner
    indoor coil sensor?
    do you have a model number and fault code and flashing light sequence?
    paul H on here is very good on fuji and from your part of the world
    Paul
    "KEEP IT COOL"
  1. solar air conditioner issue
    Last Post: 08-04-2011, 03:00 PM
  2. Replies: 0
    Last Post: 15-08-2009, 06:16 PM
  3. general air conditioner
    By husnutan in forum Air Conditioning
    Last Post: 05-06-2009, 07:23 PM
  4. Air conditioner tripping on low oil pressure.
    By g.karsandas in forum Fundamentals
    Last Post: 15-01-2009, 08:38 AM
  5. Dual mode Air Conditioner for RV
    By tkc100 in forum Transport
    Last Post: 25-07-2007, 08:57 PM
Tags for this Thread
