Results 1 to 12 of 12
19-10-2009, 06:31 PM #1
using R-134a recovery tank with other refrigerant ???
I want to ask about the recovery tank with float switch # 67010 , it comes with recovery system# 69100 from MasterCool and if this tank can be used with other types of refrigerant cooling "OR" not ?! such as : R-402A, R-507 and R-290A
I have the adapter tank R-134a (to) R-12
I hope you can help me......
Note : the link of the product is attached...
19-10-2009, 11:00 PM #2
Re: using R-134a recovery tank with other refrigerant ???
The cylinder should be capable of holding any refrigerant up to it's safe maximum fill quantity. Check the loading data stamped on the cylinder.
You will, however, suffer from cross contanimation if you use it for different refrigerants without having the cylinder cleaned between uses.Brian - Newton Abbot, Devon, UK
20-10-2009, 02:26 PM #3
21-10-2009, 08:10 AM #4
More advice please?!
21-10-2009, 11:26 PM #5
Read the instructions or contact the supplier/manufacturer.
26-10-2009, 12:47 PM #6
You must be vaccum tank before fill in other refrigerant
26-10-2009, 12:52 PM #7
Recovery of R290 (propane) involves the usage of explosion proof equipment.
Remember to retag your cylinder according to the actual refrigerant stored.
29-10-2009, 06:51 PM #8
Thank you all for these helpful tips....
I bought this machine : 69100 COMPLETE A/C RECOVERY SYSTEM ( mastercool )
And I have read the manual supplied with the machine, But I'm not sure this information is :
4. ..... Connect hose from outlet port of recovery machine to vapor (gas) connection on recovery tank.
Now..I want to know what is the right way ?
And are the differences color the valves cylinders is importance or not ?
If I use the recovery tank in charging proses and I leave the tank up side down, so what is the best way to connect hose ( Vapor "OR" Liquid connection ) ?
I attach the file that contain the links ....
Thank you all Guys,
29-10-2009, 07:02 PM #9
I'm sorry...
There was an error in the previous image of the cylinder !
I attach the right image....
29-10-2009, 07:02 PM #10
If i am filling the recovery tank with the recovery machine i would connect to the liquid tap, the idea is that the refrigerant will bubble through the liquid in the bottom of the tank keeping the pressure and temperature lower than if the gas tap had been used.
If you are emtying the tank with the machine you will want to connect to the gas tap unless your machine can cope with liquid.
Jon
29-10-2009, 07:04 PM #11
31-03-2011, 03:48 PM #12
simple answer dont mix refrigerants! use a caremaster recovery unit specially made for hydrocarbons for R290 ! availabe from hawco!
Superheat and Subcooling
Recovery tank
By dddon in forum Chit Chat & Service StoriesReplies: 5Last Post: 01-12-2008, 02:53 AM -
recovery tank question
By flyboy3b in forum FundamentalsReplies: 7Last Post: 05-12-2007, 03:25 PM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM -
Refrigerant recovery
By chillyblue in forum Technical DiscussionsReplies: 11Last Post: 23-07-2007, 10:58 PM
