Thread: Chilled water chemical treatment
19-10-2009, 06:27 PM #1
Kindly can some one tell me the name of chilled water chemical.
thanks,
19-10-2009, 11:01 PM #2
Re: Chilled water chemical treatment
What sort of chilled water chemical are you interested in?
Cleaning,
treating,
lower temperature use.Brian - Newton Abbot, Devon, UK
20-10-2009, 02:55 AM #3
Hi Roshankhan.
Close circuit chilled water systems should tested regularily for PH balance, to stop cathodic corrossion ( effectively a big battery )the corrossion is from the inside.
Talk to your cooling tower water treatment people, they will have all the chemicals required.
Probably a flush out every 12 months as well.
pure water from air
By Lc_shi in forum New TechnologiesReplies: 32Last Post: 26-02-2009, 12:25 PM -
Chilled water bypass problem
By MACT in forum Trouble ShootingReplies: 5Last Post: 16-10-2008, 02:01 AM -
Energy saving in Chilled water system
By psrao in forum Tools and CalculatorsReplies: 5Last Post: 15-01-2008, 06:54 PM -
Chilled water treatment
By benj in forum CommercialReplies: 1Last Post: 04-09-2007, 04:44 AM -
Building a wine cabinet
