19-10-2009, 04:37 PM #1
Leakage Process Preparation (R134a)
Hi, my issue refers to the leakage process preparation. I'm analysing the leakage process, and i'm interested on knowing how does the bottles containg R134a are produced and how it's leak rate is calculated.
Thks in advance
20-10-2009, 05:06 PM #2
Re: Leakage Process Preparation (R134a)
What bottles?
If you talk about refrigerant bottles, they don't leak.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
20-10-2009, 05:36 PM #3
The little bottles contain a "septum", which permit the leak of the refrigerant gas. My question concerns with the specifications of the bottle. If is any norm that determines the specifications of the little bottles, containing the refrigerant gas (material used in fabrication, nomianal diameter, etc.).
Thks for your response
20-10-2009, 07:12 PM #4
I think that you are referring to leakage test bottles perhaps.
You should contact the manufacturers if you want details of their trade secrets.Brian - Newton Abbot, Devon, UK
21-10-2009, 06:51 PM #5
Yes, I'm referring to that kind of bottles. I've contacted the fabricant but didn't get any answer. Do you know if there's any padronized fabrication system for that bottles?
Thks
r12 vs r134a minifridges (efficiency)
By ziddey in forum FundamentalsReplies: 10Last Post: 25-06-2009, 06:26 AM -
My freezer inner pipe leakage
By syaful in forum DomesticReplies: 3Last Post: 05-03-2009, 10:52 AM -
R134a to R407C
By tooltemp in forum IndustrialReplies: 1Last Post: 15-05-2008, 03:04 PM -
Pressure Transmitter R134a Setpoints
By cooltrain in forum Technical SpeculationsReplies: 0Last Post: 28-02-2005, 09:05 AM -
Is there anything about R134a that is better than R12?
By dude in forum RefrigerantsReplies: 5Last Post: 01-03-2004, 09:59 PM
