    Juan BH's Avatar
    Juan BH Guest
    Thumbs down Oil Migrates when Chiller is OFF!
    Hi-
    I'm new on the site, but it looks like a great resouce and to be honest I'm still pretty green in the commercial area.
    I was wondering if anyone has experienced an oil migration problem like this: Carrier 19XR centrifugal 1500 ton R-134a machine loses oil gradually when it is shut down over the winter.
    This past spring I had to add about 10 gallons of POE then remove it all after the stuff that migrated came back. Now that the cold is here, I am seeing the same thing happen. The chiller hasn't run for a couple of weeks now and the oil level in the sump has dropped below the lower sight glass.
    We have a 30 minute "flush" through the condenser barrel every night to keep solids in suspension, but other than that the machine is completely idle. Any thoughts?
    Aug 2009
    Turhona.libya
    79
    15
    Re: Oil Migrates when Chiller is OFF!
    Check the crankcase heater it might not function.
    scotland
    756
    you need to shut all valves in on the compressor body when not using for a long time as when its cold outside where the unit is liquid tends to migrate to the coldest point and if thats outside where your unit is it will lift the oil.
    iceman2306's Avatar
    iceman2306 Guest
    is th emachine turned off when not in use and shut down for the winter time,
    if the machine oil pump is left on and the oip pump runs through its stir cycle after a period of time it is possible for the oil to leak through the labby.
    Nov 2005
    New Zealand
    550
    Quote Originally Posted by Juan BH View Post
    Hi-
    Hi Do you drain the the cooling tower and do you leave the oil heater on?
    Toosh
    My wife used to say you never listen to a word I say at least I think that what she said
    Juan BH's Avatar
    Juan BH Guest
    What is the labby?
  1. process chiller help
    By talon771 in forum Industrial
    Last Post: 12-01-2011, 08:42 PM
  2. Absorption Chiller VS Mech. Chiller
    By Intern in forum Industrial
    Last Post: 30-05-2009, 08:31 AM
  3. Power consumption of Chiller
    By adrian116 in forum System Optimization
    Last Post: 24-04-2009, 05:05 PM
  4. York Chiller startup when on Emergency Power
    By Apollo10 in forum Trouble Shooting
    Last Post: 22-12-2008, 07:13 PM
  5. Trane CVHE 450 R11 Centrifugal Chiller
    By albertjoseph in forum Air Conditioning
    Last Post: 06-10-2008, 03:23 PM
Tags for this Thread
