    3,856
    Blocked filter...
    Been doing a bit of work on the truck, she smokes a bit when cold and i decided to run some Redex and fresh diesel through to see if it cleared up. Left her running for a couple of hours with the throttle cable tied open for a fast idle.
    Happened to look in the power steering fluid and found this....
    http://www.youtube.com/watch?v=SVJLjye8OSM
    still at least she doesn't smoke when warmed up now I have flushed it out with 50L of atf fluid, fingers crossed
    Jon
    11,025
    Re: Blocked filter...
    Well, at least it stops you getting bored in front of the TV.
    Mar 2007
    118
    moisture gettin in there somehow? Looks like an emulsion
    3,856
    Its nice and clean now after we flushed it out but i'll keep an eye on it.
    Not sure if it was due to condensation, water getting in through the vent hole in the cap or someone topping it up with water as the cooling header tank is on the back of the cab also.
    Jon
  1. Location of Suction Filter
    By Ray123 in forum Fundamentals
    Last Post: 11-06-2009, 03:29 PM
  2. Liquid Line Filter Blocked!
    By Grizzly in forum Fundamentals
    Last Post: 28-08-2008, 10:36 PM
  3. Blocked driers
    By monkey spanners in forum Technical Discussions
    Last Post: 03-07-2008, 05:55 PM
  4. questions in the method of testing filter filtration capability
    By jasonsun in forum Technical Discussions
    Last Post: 10-05-2007, 04:45 AM
  5. DW Copeland
    By Abe in forum Trouble Shooting
    Last Post: 19-11-2002, 02:54 PM
