Results 1 to 12 of 12
    Aug 2009
    Singapore
    47
    42
    Need help Computer Room Air-con(CRAC) Problem
    I'm a facilities technician and working at the data center.Inside this data center,one of the rooms has 6 CRAC units and most of the units are sweating at compressor.Please advise Is it normal or something happened?
    Suction Pressure - around 60~68 psi
    Discharge Pressure-around 220~235 psi
    Scroll compressor
    I'm new in this site and sorry if my question is wrong.
    Thanks.
    Oct 2001
    Nottingham UK
    5,668
    Re: Need help Computer Room Air-con(CRAC) Problem
    Your question isn't wrong....just posted in the wrong section, but I've moved it now.
    Suction and discharge pressures mean nothing if you don't tell us what refrigerant it is? The air on and air off temperatures are also important.
    Also, the pressures should be converted to temperature to be of any use in determining if the system is operating correctly.
    Aug 2009
    Singapore
    47
    42
    Thanks,Frank.
    Refrigerant is R-22 and air on and air off temperaturs are 17 and 21 deg F.
    Oct 2005
    IRAN
    878
    Hi there,
    Suction pressure seems OK. Discharge pressure with water cooled condenser is OK. Or with air cooled condenser with ambient temperature of around 30°C is OK.
    Measure super heat and sub cooling.
    If ambient humidity is high sweating is normal. If you have low super heat then there is a liquid flood back.
    Even Einstein Asked Questions
    Aug 2009
    Singapore
    47
    42
    I'd like to know what ambient humidity is considered as high ambient humidity?
    Thanks.
    Apr 2009
    israel
    778
    above 50% rh but all dependes on temp!!! u should use a enthalpy table and that will tell u what your duepoint is!
    Aug 2009
    Singapore
    47
    42
    Thanks a lot.
    Apr 2001
    79
    5,071
    35
    Quote Originally Posted by ksm View Post
    ... air on and air off temperaturs are 17 and 21 deg F.
    That can't be right. Measure again.
    We are talking about the air temperature entering the evaporator coil and the air temperature leaving the evaporator coil, measured close to the coil.
    Auckland
    74
    3,357
    37
    ksm,
    hopefully you are talking air temps expressed in degrees C.
    Generally in data centres you need to keep the humidity level up by adding moisture with humidifiers, due to high sensible heat loads, get the humidity too low will create static problems in computers. And create the sweaty compressor problems you have.
    Apr 2001
    79
    5,071
    35
    If the numbers are correct and indeed in degrees C, then the coil is running warmer than it should and the humidity is too high. Either unloading set too high or blower running too fast.
    But we really don't know if these systems have any form of unloading... and we don't know if the temperatures provided are accurate.
    Jan 2008
    India
    70
    171
    Reltive Humidity depends on the local ambient.If you are talking about Singapore it should be around 35 degree C and wet bulb temperature of 26 to 28 degree C and RH will be 50 to 80 %.
    When the suction of compressor has temperature(surface) less than dew point sweating will take place. And it is normal.
    From the way you have explainted it appears it is out door condensing unit and the ambient RH being high it must be sweating on the surface of suction side of compressor
    Aug 2009
    Singapore
    47
    42
    Ok,thanks.Gary.
    I will check again.Thanks all.
  1. Blind Cold room specs help
    By frostedflake in forum Trouble Shooting
    Last Post: 13-03-2009, 01:49 AM
  2. Help with Condensation in Fitness Room
    By S_Line in forum Trouble Shooting
    Last Post: 04-03-2009, 12:52 AM
  3. Inverters in server room
    By AbsoluteWDJ in forum Air Conditioning
    Last Post: 22-02-2009, 08:45 AM
  4. Computer Problem ?
    By Brian_UK in forum Chit Chat & Service Stories
    Last Post: 27-01-2009, 09:04 PM
  5. Computer Rooms
    By vspiteri in forum Industrial
    Last Post: 26-02-2002, 10:51 PM
