11-10-2009, 05:32 AM #1
Total Rebuild! Anyone up for a challange?
Ok guys, I have a big one for ya. I am rebuilding a 1953 Vendo Coca-Cola machine refrigeration system and have bought a compressor from grainger, item number 4mg93 . This one is a 1007BTU and the one I removed was a 1075
I am going to reuse the original evaporator and condenser as they are as much a part of the old machine as anything else, but the cap tube and the return line are going to both need replacement due to being brittle from vibration hardening and the machine sitting in the weather for who knows how long.
Here are my questions (please help if you can)
1. Since I am switching the system from R-12 to 134A, the capillary tube length and internal diameter go out the window. So, how long and what internal diameter Cap tube do I need to use for the rebuild?
2. I have 1/4"OD 3/16" ID refrigeration tubing in my shop I could use for the return line, but the original was about 5/16" OD and 7/32" ID. How much difference will this make in the operation if any? If its a big deal, I have to go to Johnstone to get the cap tube anyway and can get the same size as original.
3. How in the world do they get the cap tube soldered to the side of the return line and make it look so good? <<< more rhetorical, but if you know please share!
4. The compressor came with a "supply bag" that looked like a generic "throw in the box" kit that included a run capacitor. the instruction/specification sheet that came with it is about as vague as I have ever seen. There are two wiring diagrams and one shows the compressor with the cap, and one shows it without it. The drawing with it is listed as RSCR, and the one without it is listed as RSIR. How do I know which application to use??
5. On the bottom side of the evaporator, just before a 90 degree bend leading up into it, the cap tube ends into what looks like a small in-line dryer about 2 1/2" long by about 3/4" round. Is this an old filter I need to remove or is it an expansion chamber of sorts? It just looks suspect.
Thanks in advance for any help, Tracy
11-10-2009, 09:50 AM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Total Rebuild! Anyone up for a challange?
Is that compressor Matsus h i t a
http://www.grainger.com/Grainger/wwg/productIndex.shtml?from=Search&newSrch=yes&operator=keywordSearch&search_type=itemnum&action=Go!&Que ryString=4mg93&submit.x=46&submit.y=6
If yes, than that compressor is for LBP aplication and your Coca_Cola machine is MBP.
Also that capacity (1007 BTU) is listed for -10°F evaporation and 130°F condensation temperature.
Your condition is 20°F and not -10°F. That mean that replacement compressor is too big and not suitable for that machine.
You should use Danfoss FF6GK or other equivalent compressor.
What is old compressor make and model#? Or what is listed conditions for your capacity?
29-10-2009, 02:38 PM #3
Ok, I have gotten the correct compressor now. Thank you for the help, it is much appreciated. it looks as though you have a Vendo model as well. Is it a 39? I cant really tell from the tag. Heres a pic of mine. Can you help with any of my other questions? Thanks again in advance.
30-10-2009, 01:21 AM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Difference between Static and total efficiency of a blower
By arumugam in forum FundamentalsReplies: 2Last Post: 07-08-2009, 02:36 AM -
A/c Total Line Set Distance
By brianubaldo in forum Air ConditioningReplies: 5Last Post: 11-09-2008, 03:07 AM -
grasso RC 46 rebuild manuals
By centrifs in forum Industrial CompressorsReplies: 4Last Post: 26-08-2007, 12:29 PM -
total fresh air handler
By Lc_shi in forum FundamentalsReplies: 3Last Post: 19-12-2005, 09:31 AM -
Total System Charge
By dallan in forum FundamentalsReplies: 1Last Post: 27-12-2004, 08:18 PM
